Page 7 of 7 FirstFirst ... 567
Results 61 to 67 of 67
Thread: GU Christmas Tree
  1. #61
    Central Coast NSW
    Ok guys sorry to revive this thread from the dead but here goes.....Just bought the aftermarket tail lights from Fleaby and they look the goods, bought all LED globes and fitted them as the new lights came with wedge type holders...to easy....now the hard part.....From what I understand the blinker circuit will need resistors as they draw less current than regular bulb and consequently will flash like a blinker that has a blown bulb? Real fast? anyone had experience with this or am I being mislead into buying crap I dont need? Oh thought I would add also changing front parkers/blinkers to an aftermarket LED light.
    Expert mjr350's Avatar
    Sep 2014
    Port Macquarie
    You should be able to buy a non load dependant flash can or you can simply fit a resistor inline with each indicator.
    The electronic flash cans don't click from memory but I could be wrong.
    Have a read of this. Apparently you can mod a flasher unit to not flash fast if it notices a reduction in current draw.
    http://www.stu-offroad.com/electrical/led1/led-3.htm
  4. #63
    Apr 2015
    G'day Shayne,
    Just installed the after market light bezels in my Patrol. I'd like to know the easiest way to hook them up to the existing lights in the bumper. My Patrol is a 2012 so might be qa bit different from yours by the sound of it. Be good if you could point me in the right direction.
  5. #64
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    If you still have globes in your bumper lights they should not flash noticeably faster.
  6. #65
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Another one lit up
    I modified the existing tail-light fittings rather than replace them.
    But a word of warning if you go this way: If you do get some swarf into the fitting, DO NOT try to blow it out with compressed air. All the internal spaces are connected and there is a small gap between the outer skin and the inner parts, so the stuff spreads everywhere and is EXTREMLY hard to completely remove.
  7. #66
    Oct 2015
    Melbourne, Aust
    Must admit I was perplexed when I checked the back of the Patrol and found there was not even globes or spaces for globes in those huge read side lights.
    Since they are under $2, think I will try to see if some of these LED's will fit, hopefully it will be a simple operation.
  8. #67
    330 Post(s)
    Quote Originally Posted by K_Wolf View Post
    Hi Mate, please head over and start and introduction thread, we like folks to say day when they join the forum.
