18th October 2014, 11:26 AM
#21
Got it all working, though now my bullbar is slightly crooked, when I took the bull bar off there were about half a dozen washers on one side of the mount and couple on the other, got no adjustment either way bugger it because the winch cradle steel is to thick..
Had a 1999 GU ST Patrol 4.5L Auto on Dual Fuel ...now have a 2003 GU ST ZD30TD Auto.
18th October 2014 11:26 AM
18th October 2014, 02:41 PM
#22
tallman
Adjust the bar where it mounts to the bracket right up behind the bar. Loosen them enough to just be able to manipulate the bar with a rubber mallet or a good whack.
19th October 2014, 12:47 PM
#23
Thanks for that got it nice and level....had no idea there was any adjustment in that spot until you told me...cheers.
19th October 2014, 02:59 PM
#24
I originally removed the bar at the chassis to measure up and fit the cradle so everything went back together as before and the 3mm angle replaces the 3mm spacer so happy days.
I had the then remove the bar at the top mounting point to fabricate the fairlead bracket and also had no idea that there was so much adjustment there. Fitted the bar, did the bolts up tight and my mate stood there laughing because of the 3mm gap on one side and the 33mm gap on the other side. A quick nudge and all is good.
28th October 2014, 04:19 PM
#25
5th April 2015, 03:31 PM
#26
mjr350
The winch I decided on is a Tigerz11 12000lb Grande MKII as I know a few guys with them and can't fault them plus the price was what I wanted.
MJR, a bit off topic, but I was wondering if you could please post up the User Manual that came witht the winch in the Manaul section. I have just worked out that the winch in my just bought Patrol is a Tigerz11 Grande MKII. I have got it operating etc no probs but am also trying to get all the manuals and missing bits for it. Are you able to assist?
Looking for a 4WD Club in WA that caters solely for Patrol, Safari and Maverick owners? Click here to HERE to visit the Western Patrol Club. Click HERE for the Beagle Mobile Mods!
5th April 2015, 07:02 PM
#27
I'm away for the weekend at the moment and to be honest I have no idea where the manual is or if I still have it. Ill let you know when I get home.
It looks to be identical to the supercheap ridge rider 12000lb winch as well.
The Following User Says Thank You to mjr350 For This Useful Post:
LaughingBeagles (5th April 2015)
5th April 2015, 07:17 PM
#28
Thanks mate, and appreciate you looking.
19th April 2015, 11:41 PM
#29
Been looking as i go. Can't find it sorry
16th April 2016, 11:13 PM
#30
threedogs
good job nice and solid , I especially like the idea of putting the winch control socket inside.
I fitted a yellow latch lock hook,, you can fit more straps etc in it if required
x2 on putting the socket inside the cab ,
Will be doing exactly that , using this thread as inspiration.
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
