Results 1 to 10 of 17
Thread: Help with list of RWC fixes please 1989 GQ 4.2d Wagon
    Apr 2015
    Albury Wodonga
    Question Help with list of RWC fixes please 1989 GQ 4.2d Wagon
    This is the list I got back for RWC and I would appreciate any info, fixes or source of parts please
    Steering wheel grip loose: fix/glue or aftermarket wheel
    Drivers side seat belt frayed: Replace where do i find aftermarket or how to fix?
    Front trailing arm bushes under diff stuffed: Replace parts supply aftermarket?
    Disc pads need replace all around: best type?
    Rear axel seals leaking: advice on fixing and new seals?
    Both front door hinges both sides: replace parts supply aftermarket where to buy?
    Fuel tank signs of leak from above maybe when filling? any advice
    When on hoist one of the rear coil springs wants to fall out? shocks or something more sinister?
    Thanks in advance.
    I use Bendix 4WD brake pads, they are the best in my opinion.
    With the steering wheel, fill a syringe with super glue and stick it in, just inject it around the steel bar and leave for a while, that should fix it.
    what wrong with the front door hinges ??
    X 2 with the needle and super glue trick
    Legendary Alitis007's Avatar
    15 Post(s)
    Quote Originally Posted by glennboy View Post
    Thanks in advance.
    Aftermarket steering wheels need to be the same diameter as the original or ot wont comply. To repair the original if you're are unable to do it yourself you can get a bloke to come out on site to glue it.
    Repco and bursons should be able to organise aftermarket units or get some good second hand ones
    Go genuine rubber pm Mudski he should stock them or try Patrolapart if Mark doesn't have them.
    As Winnie said Bendix 4wd are the best still ausie made even tho they're owned by trw now but still THE BEST!!
    Genuine new or second hand hinges, no aftermarket units available. Why did they fail anyway???
    Drop the tank to see if a hose or the seal has perished. (I had a crv come into work the other day and the cap that hold the sender unit down was loose and was leaking when full)
    Maybe your spring has sagged?? Or tye shocker is too long for your spring travel
    That should keep you busy for a little while
  5. #5
    81 Post(s)
    For the steering wheel, I cut some small holes at intervals on the inner side and used a caulking gun to pump silicon between the grip and the steel. I then taped over the holes and kneaded the silicon until it was even. After the silicon was dry I removed the tape. It lasted for ten years.
  6. #6
    Nov 2010
    Getting a life...
    38 Post(s)
    Door hinges : dont buy cheap aftermarket ones, they'll last a month if your lucky. Go genuine Nissan and you never have to do them again.( patrolapart or maybe ebay) Replace the whole hinge. Just replacing the pins is a PITA.
    Frayed seat belt; cant be repaired, must be replaced.... wreckers would be your best bet.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  7. #7
    Patrol Guru matfew's Avatar
    Nov 2012
    Where are you. I might be able to help with some parts as I have a wrecked gq sitting it the back
  8. #8
    Apr 2015
    Albury Wodonga
    Quote Originally Posted by matfew View Post
    Albury Wodonga,
    I am getting prices for above parts from Nissan and Patrol a Part, May just bite bullet and get 2" lift kit with shocks. Steering wheel fixed buy guy who injects glue for $50.
    New seat belt from Nissan $185
    door hinge's Nissan $444
    Brake pads sorted
    Axel seals Nissan $11 inner $45 outer x 2
    Front bushes Nissan $40 ea x 4
    Iron Man 2" lift kit with HD shocks $1,250.00
  9. #9
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Where are you at matfew?
  10. #10
    Apr 2015
    Albury Wodonga
    I recon the springs are sagged and just pulled the iron man shocks off and one feels stuffed, Iron man springs +50mm and foam cell shocks for $1200 any good?
    Fixed steering wheel $50 glue injection.
    Still can't see where fuel tank leak is pulled the inspection hatch from in the back lots of dirt but nothing wet around sender, pulled the filler rubber cover off and can't see any wet there etc Bugga May have to pull the tank out
    new seat belt from Nissan $185
    Looks like only the top hinge's are stuffed may buy genuine drivers and cheep passengers
