Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Diff Bracing
    You can do it in a lathe, use a torch and do it by eye or the best method is to make a bar that goes all the through the housing inc the centre and uses bushes/discs that slide onto said bar and into the axle seal area. Now if its straight they go straight into the seal are if not its clearly visible which way it needs to go.
  2. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    BigRAWesty (10th April 2015), Parksy (10th April 2015)
  3. #12
    Quote Originally Posted by Parksy View Post
    Nope. Just winged it and hoped for the best. But the last wheel alignment shows that both wheels are almost at 0 degrees so all good. How do you check for straightness?
    Well that's how I did mine.
    Stared and finished at 0 so yea.
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Here's the last wheel balance.
    I did post a thread on methods on how to weld the diff so to not bend the thing. Surprisingly, the rear diff housing has a slight bend in it, but I've fixed this.
    IMO and should be taken with a grain of salt.
  5. The Following User Says Thank You to Parksy For This Useful Post:
  6. #14
    Advanced Maxgq's Avatar
    Mar 2013
    nunawading, Vic
    Cheers for the help blokes! Looks like they have come up pretty good
    *TD42* 2 inch suspension, 2 inch body, dts turbo, 3 inch exhaust, twin lockers, bighorns
  7. #15
    Mar 2013
    nunawading, Vic
    Forgot to ask, did you guys buy a kit from somewhere or make one yourself?
  8. #16
    Ebay. Can't make it for that price
