10th April 2015, 07:48 AM
Diff Bracing
Who here has braced the front diff on their gq? If you have, how did you go with sump clearance? i have read that it may be an issue... my car has 2" suspension and 2" body lift
![Gday](images/smilies/gday.gif)
*TD42* 2 inch suspension, 2 inch body, dts turbo, 3 inch exhaust, twin lockers, bighorns
![Smiley Thumbs Up](images/smilies/smiley_thumbs_up.gif)
10th April 2015 07:48 AM
10th April 2015, 08:09 AM
should be right are you using 50 x25 x 3 RHS sliced on an angle.
You'll also need the small weld on piece for the ball knuckles
http://www.ebay.com.au/itm/Nissan-Pa...item27f69da341
10th April 2015, 08:44 AM
Have braced my front and rear diff. Haven't had any clearance issues as yet.
The Following User Says Thank You to Parksy For This Useful Post:
10th April 2015, 09:32 AM
Yep. Braced mine.
Made absolutely no difference to clearance as you brace the top side, not the bottom.
10th April 2015, 09:33 AM
10th April 2015, 09:47 AM
biggqwesty
did you remove to weld or do in sitcu
10th April 2015, 06:17 PM
threedogs
Yea did it when I had it all apart to do the rebuild.
10th April 2015, 06:37 PM
Did you guys make sure it was straight pre and post welding?
10th April 2015, 06:46 PM
Nope. Just winged it and hoped for the best. But the last wheel alignment shows that both wheels are almost at 0 degrees so all good.
How do you check for straightness?
10th April 2015, 06:49 PM
nissannewby
Yep.
And braced and kept heat even.
