Who here has braced the front diff on their gq? If you have, how did you go with sump clearance? i have read that it may be an issue... my car has 2" suspension and 2" body lift
*TD42* 2 inch suspension, 2 inch body, dts turbo, 3 inch exhaust, twin lockers, bighorns
should be right are you using 50 x25 x 3 RHS sliced on an angle.
You'll also need the small weld on piece for the ball knuckles
http://www.ebay.com.au/itm/Nissan-Pa...item27f69da341
Maxgq (10th April 2015)
Yep. Braced mine.
Made absolutely no difference to clearance as you brace the top side, not the bottom.
Here is a pic
Did you guys make sure it was straight pre and post welding?
Nope. Just winged it and hoped for the best. But the last wheel alignment shows that both wheels are almost at 0 degrees so all good.
How do you check for straightness?
IMO and should be taken with a grain of salt.
