Hi all. The bullbat I'm going to put on my ute is to suit a 2" body lift. Whoever modded it did a dam good job, and I don't feel like modifying it back.
So I'm going to lift the suspension a bit less, and put in a 2" body lift.
So, poly blocks or alloy blocks? What would you use?
Also, I'm going to be making these myself. So if anyone knows the thickness of the crush tube in a poly block, that would be great! Thanks
Cheers.
