Sorry for the 50 questions but when covering those service holes did you just stick the dynamat straight over them or did you cover them up with something first? I see a lot of people cover them with some thin mdf
When I covered up the service holes I stuck some of the old plastic liner so nothing would stick to the dyna mat.
Winnie (2nd March 2015)
Awesme job Flex feel free to pop over and wire up my amp,
everything is here,ready to go lol
Going to remove the amp from the cargo barrier to under the front left seat.
Makes sense less wire
OOI what side of Melb you on??
Under the seat is a good place, however it's not very flat as the rear air vent ducts are located there. You may need to make a shelf.....
I'm located in Greensborough, Melbourne
ok not far away now with the ring road Im over Deer Park way.
Ill remove the seat and see where I can make some brackets fit
What about if your car goes swimming 3d's? Id put mine under the seat but worried that it might go for a swim one day
Lucus30's 1999 GU ST TB45E
such is life, wow you going through some deep water to get that high,
I dont do bog holes way too expensive so it would only be river crossings.
Plan is not to get it wet, but my cargo barrier is only a half cage so its mounted shoulder height atm.
did flood the other 4x4 a few times I must admit, any suggestions
I will be putting mine either on the cargo barrier or screw it to the back of the drawers.
Yeah I like the under the seat idea. Least then the Ms won't see it and ask when i got it ha ha
threedogs (27th April 2015)
