Results 1 to 10 of 13
Thread: Fitting water temp gauge
    Is there a place to put the thermo couple or could I use the adaptor in the link.
    not saying thats the corect one but would be similar
    http://www.ebay.com.au/itm/Water-tem...item25a004793f
    brisbane
    That's similar to the one I used, not leaked in 4 yrs
  4. The Following User Says Thank You to megatexture For This Useful Post:
    threedogs (14th February 2015)
    That one is for a WRX... it will only work if you have a 12 inch exhaust tip, Jet Pilot Stickers and 21 inch rims.
  6. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    AB (13th February 2015), Bigcol (13th February 2015)
  7. #4
    49 Post(s)
    Hahahaha... love it.
    I brought this one
    Still need to get wire and make up a box to fit the gauge that will house some rocket style switchers as well.
  8. #5
    175 Post(s)
    John. Just curious. Why? Can't you read your water temp through the scangauge or whatever you have ? That's how I read my one.
  9. The Following User Says Thank You to Hodge For This Useful Post:
    Bloodyaussie (14th February 2015)
  10. #6
    @ Hodge its a grey on green display on the ECU-Talk hard to see at the best of times.
    I think a single cup above the pillar gauges I have now will work.
  11. #7
    Thomastown, Melbourne
    6 Post(s)
    On advice with my efi motor I did not use one of those ... I prefer to tap and thread.
    The td42 has the perfect spot (thanks matfew for pointing it out) and looks factory rather than cutting good hoses all the time.
  12. #8
    174 Post(s)
    Nah, you’re gonna need a triple pod otherwise it’ll look crap.
  13. #9
    Wont be cutting any hoses I'll introduce another piece the same diameter.
    If I can drill and tap somewhere all the better, too humid to look ATM
    ALL good but I have a 3ltr so that no good to me
  14. #10
    Not 100% sure what style gauge Im getting ATM I've found some the same size as the ACU-Talk with an alarm.
    Just need to look at where it'll fit best. Maybe a small over head unit not sure yet.
    it will have and alarm
