Results 1 to 10 of 10
Thread: Fitting Lift Questons
    Aug 2013
    Adelaide
    Hi all.
    This weekend i plan on fitting the 3" lift to my car. Just wondering if i will be needing to compress the springs or ill be able to get enough clearance to put them in? I will have access to a hoist for the job hopefully that will make it a little nicer than rolling around on the ground. Also any other nasty suprises i'm in for?
    Life's a garden dig it.....with all 4 wheels.
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    On a hoist you should be able to get springs in by just unbolting shocks , sway bar links and brake line t junction at diffs
  4. The Following User Says Thank You to liftlid For This Useful Post:
    Bigbird91 (3rd February 2015)
    Aug 2013
    Adelaide
    Beautiful! Just what i wanted to hear liftlid. Hopefully i still have some skin left on my knuckles afterwards.
    175 Post(s)
    Word of advice.
    Don't do it under a carport or garage, which you won't be able to get out of, once the vehicle is lifted / standing taller.
    Yes, it has happened.
  7. The Following 3 Users Say Thank You to Hodge For This Useful Post:
    Bigbird91 (4th February 2015), neet_wagon (5th February 2015), NissanGQ4.2 (3rd February 2015)
  8. #5
    330 Post(s)
    Word of advice.
    If that happens just deflate the tyres, roll out, reinflate, drive away and find a new parking spot
  9. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
  10. #6
    Aug 2013
    Adelaide
    They say a silly question is better than a silly mistake so here it is. With the stabilizer bar release assembly still fitted what would i do with the link arms for the sway bar, do i need to ditch it for extended links?
    cheers
  11. #7
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by Bigbird91 View Post
    They say a silly question is better than a silly mistake so here it is. With the stabilizer bar release assembly still fitted what would i do with the link arms for the sway bar, do i need to ditch it for extended links? cheers
    Most likely with a 3"lift??
  12. #8
    Aug 2013
    Adelaide
    Dang it, that's what i was thinking would be the out come. I might have a look to see if i can mod it to work.
  13. #9
    Boarder 4x4 fab in boarder town, sa do a extended release unit. Unsure of cost thou
  14. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Bigbird91 (15th February 2015)
  15. #10
    Aug 2013
    Adelaide
    Cheers Westy I'll give them a buzz.
