Page 459 of 1056 FirstFirst ... 359409449457458459460461469509559959 ... LastLast
Results 4,581 to 4,590 of 10551
  1. #4581
    Nov 2010
    Lobethal, South Oz
    Put a new Radiator in the old bus, only to have the starter motor die!
    So I gave it a wash and it will sit there till i can afford a new starter motor!
    Jul 2012
    N/a
    Got the GU a bit muddy and put the GQ up for sale on Gumtree
  4. #4583
    Patrol God Stropp's Avatar
    31 Post(s)
    Turned the boost up to 20 psi
  5. #4584
    Nasty Dog - Moderator Woof's Avatar
    Perth WA
    61 Post(s)
    I was running 25 in the Q mate, did the clutch and rear engine seal.................be careful
    If any members require assistance in anything regarding this forum, just let me know via a PM and I will help you in any way that I can.
  6. #4585
    31 Post(s)
    Yeh mate easy does it, I may back it down to 18
  7. #4586
    Germany and NZ
    Quote Originally Posted by FNQGU View Post
    Anyway, at least the bearing grease all seemed to be fine, so I'll source a retaining clip, add a bit more grease and make things right tomorrow.
    I did about 50k km in mine with no clip on either side, fitting them does not seem to have made much if any noticeable difference.
  8. #4587
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    I think you're right, but I put em in anyway, with a nice new set of screws too. All good now.
  9. #4588
    Jul 2012
    N/a
    Sold the GQ and covered the GU in mud again
  10. #4589
    175 Post(s)
    New bit of light LED kit.
  11. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    Bacho86 (28th January 2015), threedogs (28th January 2015)
  12. #4590
    Wired up my roof rack, as I put some clearance lights on, they may also serve as DRLs not sure yet.
    Plus they are indicators as well.
    The 27watt flood light at the back I decided I'll use via a switch in the back to keep the troops happy.
    I have plenty of reverse lights as such
