Covo,
I would also take up Heath's generous offer of assistance, as there does seem to be an issue, and two sets of eyes and hands will be helpful
Mic
Covo,
Mic
Yep, i think another set of eyes would be good. Just checked turning tail shaft and watching wheel. about 4.3 turns for 1 turn of the rear wheel. about 5.1 turns for the front wheel to turn once.
Well, I would call it as 4.3 ratio in the rear but jury is still deliberating on the front... 5.1 is "interesting" so maybe 4.6 ratio out of a 2.8 or 4.3 and something else is stuffed?
What ratio is on the compliance plate?
HG43 on the plate so I believe that is 4.3.
Anyone on here sell diff gears? How hard is it to change over?
4.3's are a fairly common size.
Should be able to pick up a set from either the wreckers, or maybe your local fourby shop tnat is putting in difflocks
You could try K&A 4wd wreckers in Orange to see if they have a complete centre. I got one off them about a year ago for my old hilux and from memory it was $300
Hi Happygu, do they not still use it if they put in lockers?
