Okay, more progress / photo's, two batteries in place of one, now 240 Ah.. problem is I had to rip out the existing panel and cut an extension and move the panel back (aft).
2004 4.2TD ST, Berrima Diesel Injector Tuned, Viper 3" SS exhaust, Cross Country Ultimate Intercooler, Solvaris sound proofing, DigOptions GPS/MMU, 220mm Roo Lights, PIONEER TS-D1602R 6.5" x 4 speakers, Autocar EGT&Boost gauges, Brown Davis 80L Aux, Icom 440, Alloy drawers and cargo barrier, 2" Amanda Extreme / Dobson / PolyAir lift, CSA mags with Toyo ATII tyres, Rhino Pioneer roof rack now with brackets, Performance 4x4 16g Large.
Cut out first picture and moved existing panel with switches aft and Projecta Charger and Inverter remote heads mounted.. complete
Prototype ally frig slide cut and folded and installed.. now the top clears the box anyway, have to move the frig a little bit out when the top is opened.
[QUOTE=HuskyInAuz;574094]thats not going anywhere in a hurry, must tow like a dream being so long [drawbar]
More info on towball weights at 200kg the payload stays the same on a diesel auto,
At 250kg the payload is reduced by 150kg.
But we all over pack I think.
Id hate to weigh some patrols I've seen [Yes Cuppa You lol]
Dual batteries installed and fused, 30A charger, 1000 watt sine wave inverter installed, solar regulator installed and tested, changed cigarette lighter plug to Anderson for fridge..and ... prototyped and installed the new ally front, pictures, when I get unstuck from trying to go to meetup with road tyres.
Front platform needs to be modified, wiring is undersized to frig, that will have to be changed.
Still have to pack and installed 8 tie down hooks for solar panel, gazebo and step ladder.
I have been keeping tabs on weights, will do a tongue weight tomorrow. I see Kamar (sp?) has a rear bumper upgrade to 350kg.. Putting some water/diesel on the back will counter what going up front, I have about 80kgs to play with.
