Thanks,, what the towball weight on your trailer ?
2004 4.2TD ST, Berrima Diesel Injector Tuned, Viper 3" SS exhaust, Cross Country Ultimate Intercooler, Solvaris sound proofing, DigOptions GPS/MMU, 220mm Roo Lights, PIONEER TS-D1602R 6.5" x 4 speakers, Autocar EGT&Boost gauges, Brown Davis 80L Aux, Icom 440, Alloy drawers and cargo barrier, 2" Amanda Extreme / Dobson / PolyAir lift, CSA mags with Toyo ATII tyres, Rhino Pioneer roof rack now with brackets, Performance 4x4 16g Large.
Not interested in 9kg gas bottles, 4.5's are fine, the rack was heavy as crap and the new front mod (just doing prototype now) will have a HD alloy shield with a bit better airflow. Those mods will not be done before NP AU Day meetup.
Keep everyone posted.. trying to get 2x120 ah batteries in there now, inverter, PV controller tonight.
Just looks heavy with the coupling being so far from the axle it looks very front heavy to me.
maybe 10' from the wheels to the coupling is it, or is that front box empty
Front box has the frig on one side, nothing else right now ..
TD, your in trouble with my wife, first pictures of frame at lunch, now going to bed but instead I'm going out to measure ...
I had all the tent poles, awnings, etc in the front when we took delivery, 'trol didn't move a bit when we hooked up. maybe 10mm I was really surprised.
If you look at the rear frame there is a blank receiver but on either side there are two frame receivers where that spare holder and receiver slots into. I'm going to add a small box on the right side to hold the chemical toilet and the center to left side 4 20L water containers, that will effect the CG aft.... 'course could be smok'n dope too
Center of Tregg to center of axle 3720mm..
A lot of the unit is ally plate btw.
I will try and to a loaded tongue weight before too many more mods. I know one owner already added jerry cans AND the spare tire up front.
Tongue weight with frig in front box, 114 kg
not too bad just about maxed out, but wow nearly 4 mtr draw bar no flex using the 100x50x3 rhs I take it
Sorry to your missus too lol
I think some towbars have a 200kg load rating and others have 350kg rating that down force
[QUOTE=threedogs;573994]not too bad just about maxed out, but wow nearly 4 mtr draw bar no flex using the 100x50x3 rhs I take it
100x50x4mm drawbar... Had the blue slip today, shop was impressed underneath, I wasn't with the paperwork. Need to talk with Mark but we over came and now it has a license plate.
threedogs (21st January 2015)
