Yeh I think I can order the straight through pipe
Avo (3rd January 2015)
So the diesels are not too loud without a muffler, never knew that. I assume the TB's require one as all kits I have seen are sold with one?
I'm also interested in hearing how you found the new exhaust. I have been quoted $1,300 for a 3" Redback system fitted but these guys are advertising what appears to be pretty much the same for $605 delivered.
http://www.ebay.com.au/itm/Nissan-GU...item3a88933d45
What would the difference be (apart from the fitting) that justifies the price difference?
2009 ZD30-CRD Patrol ST Wagon. Bullbar, IPF Spotties, Snorkel, BFG285/70R70, 2" OME Lift, Rear Drawers, UHF, Scangauge, VDO Boost and EGT Gauges in an A-Pillar Pod, More bits
That's the same system I have. You can call them up and talk to you them if you have any issues as there is a phone number on the receipt. I'm not sure what you get for double the price. They do stainless as well for less than the others mild steel.
growler2058 (4th January 2015)
I might do that!
It's a Crd mate
