John
Speaking of voltage drop when starting, is there a way to stop the headunit from restarting when i crank the motor without hooking to the aux battery?
Is it wired direct to battery or via something else.
All batteries have an "internal" resistance. The value of this resistance depends on the level of charge and the health of the battery, but is usually very small (fractions of an ohm). This internal resistance can be thought of as a series resistance when thinking about a vehicle wiring diagram. Like any resistance, the voltage dropped over it is proportional to the current passing through it (V=IxR), and the more current that is drawn from the battery the more voltage will be dropped over the series internal resistance. With this in mind, the thickness of your battery cable will not change the internal resistance of the battery. Sure, you need to have a decent sized battery to winch cable in order to minimise the voltage drop over the cable, but when you start to operate the winch and draw lots of current you will always get a voltage drop due to the internal resistance of the battery.
