Hi everyone tomorrow im going to replace my central locking in my 92 gq. I was wondering which way the standard locks unlocks from the positive or negative. I am going to put some aftermarket locking system in (cyclops).
I was also wondering if I could just keep all the factor wires and just replace the motors themselves.
But I went a complete stand alone system with keyless entry and added a second master to passengers door. Placed the 4th kit actuator in the rear door..
Sorry got the make of the aftermarket kit wrong its a trackpro
I have started and now im stuck I having troubles working out where to mount and install the new units. I am unable to resue the factory wires as the new unit has 5 wire for the front units.
It is. Should have remembered that.
I'll try find my diagrams but I'm pretty sure the the 2 wires coloured the same as the other (green and brown from memory) will activate the unit. The other 3 and for the auto setup.
Now the patrol uses 3 so I'm unsure how that works but I'll assume the master sends a signal back to controller unit.
Like I said I just installed stand alone so from here on in I'm blind.
I mounted mine in place of original actuators and ran rods in place solid fixed. I did not use the clamp crop they supply. I'll see if I can find some pics
The fist photo is the master unit, there is 2 of them. The wire colours are green, blue, white, brown and black.
The second photo is the other doors I have 3 of these. The wire colour are blue and greeen.
Exactly the same as mine. So your blue and green are what throw the until in and out.
The other 3 are signal wires. Tbh I don't think it can be done. For some reason the new units need the 3 signal wires. The originals only need one.
