Punderhead (19th November 2014), TPC (18th November 2014)
take the door up cuppa...use rope or small ratchet straps to hold it rolled....let the u bolts off...the spindle will spin to neutral position....is ok...if you can get a hand to lift it down ..then lift it down...move the brackets up the desired height ..put door back on them and u bolts...leave straps on and rotate door about 2.5 turns to retension..if you have no motor then you have to use a weight on the floor and small rope to handle or something on door to stop it spinning back so you can take the straps off and pull door down....what are you doing about the guides and the lead in ?...I used to instal them...plus check how much of the door is left on the roller before you lift it too far....I have left half a foll on before but that is cutting fine
the one thing wrong with middle age ...is knowing you will grow out of it !
Competitions that require facebook...
Facebook in General.
93patrol (18th November 2014)
@ Cuppa why not let the air out of the campers tyres,
or get smaller tyres when at home to move it around
Never won a competition before... not likely to at this rate. A shame really as I'm in the market for an airbag kit.
yeh... took 18 months to delete the account I used to have, not making that mistake twice
