Results 1 to 5 of 5
Thread: Smart Fuel Mixture Display for Fuel injected Cars
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Smile Smart Fuel Mixture Display for Fuel injected Cars
    Another gadget for the patrol..........This new ‘smart’ version has a few additional touches such as auto dimming for night driving, emergency lean-out alarm, and better circuit protection. Another great feature is the ‘advance’ display, which operates when the ECU is operating in closed loop. Closed loop means that the air/fuel ratio is optimum for fuel economy and emission performance. Kit supplied with PCB and all electronic components.
    * Car must be fitted with air flow and EGO sensors (standard on all EFI systems) for full functionality.
    1999 GU 4500 dual fuel
    Il dado č tratto
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    Actually they only work in closed loop because they connect to your narrowband sensor.
    I built their 1st version some time back then installed a wideband sensor with a correct AFR gauge.
    I'm sure I still have it lying around somewhere if you want it..
    John
    Feb 2013
    Broadford VIC
    Thanks John. When I fix that exhaust I'll take you up on it. I think the exhaust job is getting closer to the top of the job pile
    Il dado č tratto
    Morayfield, QLD
    13 Post(s)
    Shane, do you have an Ecutalk readout? They are by far the best investment. You can see what your O2 sensor is doing (within its narrowband range) along with a whole lot of other good info like battery, engine temp, injector duty, timing, etc..
    John
    Feb 2013
    Broadford VIC
    No mate, I think I need to look into it. Cheers.
    Il dado č tratto
