5th January 2014, 11:14 PM
#21
Well mate I am out of ideas. Maybe try a diesel mechanic or fuel injection specialist
5th January 2014 11:14 PM
6th January 2014, 02:08 PM
#22
Anyone can recomend me one for a honest diesel mechanic in melbourne
mk patrol sd 33turbo diesel, bullbar, roof racks, driving lights, efs 2 inch lift, 35" Federals, Rear qtr chop.33" led lightbar..
6th January 2014, 02:15 PM
#23
7th August 2014, 11:54 PM
#24
Hey Ferret, Did you get this sorted?. I had issues with my sd33t some time back. It would cut in and out a bit or cut out just after starting.
Two things to check. Check that the Oil presure sender wiring is not shorting on metal parts down near the dip stick area. And check that the rubber boot that protects the oil pressure sender is not full of water.
These two little issues were all that was wrong with mine.
Cheers Ric.
17th September 2014, 07:40 PM
#25
I don't know if you fixed it or not. But the fuel tank sounds like a blocked breather. I've seen tanks almost suck themselves in to the point of breaking the fuel sender from this issue.
But the fluttering sounds like air in the fuel. A quick way is to get clear fuel line and run to and from your filter to the injector pump. And look for air bubbles with the engine running.
