Results 1 to 10 of 13
Thread: TD42 in a GU replacing a RD28
    Beginner Barfly's Avatar
    Jul 2014
    Will the TD42 engine go straight onto the existing engine mounts?
    would the gearbox have to be changed?
    would a TD42 with the original box go straight in.
    Cheers Max.
    When I read about the evils of drinking, I gave up reading.
    Henny Youngman
    Patrol Freak krbrooking's Avatar
    Beveridge, Melbourne
    Short answer.... No.
    I think at minimal the left mount needs moving and the 2.8 gearbox will not suit as well. You also have to change the tail shaft and diffs as they are not compatible either. There is a few threads on here regarding this subject, so if you do a search you are sure to come across the info you are looking for.
    Sent from me using Forum Runner
    Live life, Love life.
    Snatch straps on towballs can harm and/or kill!!!!!!
    Pretty much what Kev said, plus you need to change brakes. It can be done but you would be better off finding a roll over gu td42 and swap everything over. If your still keen on the conversion.
    Dec 2014
    Russia
    TD42 be changed only with box together. To set the cable to the gas pedal. Put the oil filter of a smaller size. To coordinate the transaction. That's about it.
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Just curious why you say the brakes need changing?? They are exactly the same between GU models (except tb48)??.
    I have done this conversion mate and as alluded to by Kev you will need to move the drivers side engine mount (or fabricate an offset plate), you will need a TD42 gearbox and crossmember, diffs can stay as they are but at 4.6:1 you will most likely need larger tyres or it will rev a bit on the highway, front tail shaft is the same, rear will need some flange changes either on diff end or T/case.
    Extrimal mentioned the throttle cable also need swapping over. There are off course other little bits and pieces which need modifying or using TD42 stuff. I had a complete donor so just swapped bits as needed using everything from the TD42.
  7. The Following User Says Thank You to sooty_10 For This Useful Post:
    mudski (23rd March 2015)
    Advanced ako89's Avatar
    Mar 2015
    Its a pretty easy conversion just weld in new mounts change the box and your away
  9. #7
    Beginner Cyrusbilly's Avatar
    Feb 2015
    Ballarat
    Hi If it is one thing it is not a quick conversion. I am in the process of doing a RD28 to TD42 T conversion, i just modified the drivers side engine mount to suit (have picture if you want) i used a GQ TD42 ute as my donor car. The Ute had no AC so i used the RD28 AC compressor and modified a TB42 AC mounting bracket. Wiring is different so i had to rewire the TD wiring loom to suit the RD. I sold the donor car to quick to fund the project but i have found that there are parts that i needed so i should have held on to it. Clutch fork is on the other side of the bell housing so you need to allow for this. I too have kept my 4.6 ratio diffs so i have to modify my drive shafts to suit. Not sure about the clearance of the front drive shaft with the cross member it looks a bit close but that is next weekends job.RD radiator fitted using a TB42 shroud. Power steering pump different. Hopefully the conversion will be finished soon.
  10. The Following User Says Thank You to Cyrusbilly For This Useful Post:
    rusty_nail (23rd March 2015)
  11. #8
    Quote Originally Posted by sooty_10 View Post
    Haha! You don't. Its only part of the driveline thats different. Maybe i was thinking the brakes as part of the driveline for some reason. Thanks for pointing this out.
    The RD28's use the smaller H233B rear diff though don't they? Not the larger H260 rear.
  12. #9
    Quote Originally Posted by Cyrusbilly View Post
    Start up a new thread mate with pics. This will help other wanting to do the same.
    rusty_nail (1st December 2017)
  14. #10
    Apr 2015
    west of brisbane
    good luck with it all. there must be a pile of motors somewhere that we didn't want.
