9th August 2014, 06:54 PM
Please help!
I've tried belting this thing out with no luck. At the moment, I've got some scissor jacks on it trying to pull it out and it won't budge. I've lubed it up and will leave it over night. But surely someone has a great idea that will work...
Thanks all
Andy
9th August 2014 06:54 PM
9th August 2014, 07:26 PM
Hardcore
Such is the rule of honour.
The Following 7 Users Say Thank You to macca86 For This Useful Post:
Ben-e-boy (9th August 2014), gaddy (9th August 2014), Maxhead (29th August 2014), MudRunnerTD (9th August 2014), NP99 (9th August 2014), Parksy (9th August 2014), Sherro (10th August 2014)
9th August 2014, 07:30 PM
Hardcore
I would try using an oxy set and heat up the outside box section till it gets a dull glow the with a chain around the tow ball or remove ball and use hole drive away from it either tied to a big tree or a forklift or something while it's still hot. It should expand making it pop out then clean inside and out to get rust out then put it back in covered in grease should be sweet
Don't shock load chain a steady pull should do
The Following User Says Thank You to macca86 For This Useful Post:
SPAMINATOR
The Following User Says Thank You to growler2058 For This Useful Post:
9th August 2014, 07:33 PM
growler2058
I put a sling around it tied off to a tree and drove off worked easy as
Make sure you run a pin in it and tether so it does not shoot off .... we had one take off down the street once (yes I know )
The Following User Says Thank You to Bloodyaussie For This Useful Post:
9th August 2014, 07:40 PM
Moderator
Really big hammer. Big sledge hammer. Hit bot sides sideways a few times hard the belt it out. Try this. Few times. Heat it up and hit it again.
I doubt very much that the jacks will work mate.
Check out my Toy -->
Rogue Dung Beetle
9th August 2014, 07:42 PM
Might sound funny but if it is rusted/seized in there use coke (the drink) leave it for a couple of min and give it another go.
Live life, Love life.
Snatch straps on towballs can harm and/or kill!!!!!!
The Following User Says Thank You to krbrooking For This Useful Post:
9th August 2014, 08:00 PM
Moderator
Yeah you could try a block and tackle around a tree for tension the give it a good hit. I would not do the dive away option though! It could end very badly
Rogue Dung Beetle
9th August 2014, 08:04 PM
Ahh, had this on my last Pursuit Ute.
What you have to do is act real serious like. Stride up to the side mirror and whisper, in your real serious tone, 'sorry buddy, but we've gotta tow a Cruiser' and it should spit the hook straight out in disgust.
Great dealings with: Rex;
The Following 6 Users Say Thank You to briscott For This Useful Post:
Family4x4 (30th August 2014), MudRunnerTD (9th August 2014), Parksy (9th August 2014), Sherro (10th August 2014), warner01 (3rd September 2014), Wizard52 (30th August 2014)
9th August 2014, 09:30 PM
have had one of these myself spray the crap out of it put some tension on it heat if you can and lay into it you will need at least a 4lb hammer. its just mud and rust in there make sure you hit side to side and top and bottom.
07 crd,,bridgestone 697lt, 2.75 buedesert ex,
SOLD theres a lot of my blood, sweat and money in that troll.
92 gq ti tb42efi my brothers gq extractors dual batteries brake controller uhf alloy bullbar
SOLD with a heavy heart but gone to a nice young fella
13 y62 the beast that burbles
The Following 2 Users Say Thank You to kevin07 For This Useful Post:
Parksy (9th August 2014), threedogs (29th August 2014)
