29th July 2014, 06:36 PM
Some advice on panhards and trailing arms etc
Hi guys I need to replace some of the bushes on my GQ for it to pass its warrant and I am just debating whether to buy brand new front and rear panhards, and new adjustable upper trailing arms and possibly new lower ones too. Can someone tell me some of the advantages of getting aftermarket ones rather than just rebushing the existing ones? I am running a 2" lift with 35" tyres if that makes any difference. Thanks
29th July 2014 06:36 PM
29th July 2014, 06:47 PM
The original equipment only had a 2mm tube wall. I think this is reason enough to not bother with re-bushing.
IMO and should be taken with a grain of salt.
The Following User Says Thank You to Parksy For This Useful Post:
chrisc2306 (29th July 2014)
29th July 2014, 06:52 PM
The Following User Says Thank You to growler2058 For This Useful Post:
29th July 2014, 06:59 PM
Thanks guys! I'm thinking I'm going to replace front and rear panhards, the tie rod definitely. What are your views on this bush kit? http://www.onlineautoparts.com.au/bu...-set/ZPN-02112
29th July 2014, 07:02 PM
29th July 2014, 09:07 PM
Moderator
chrisc2306
Rubbish. Buy Rubber, buy OEM.
If your looking to use your 4wd in the bush then the list below would be what I would be upgrading.
I would buy HD Lower trailing arms,
HD Tie Rod
HD Drag Link
Replace upper trailing arm bushes if needed?? Would be surprised if you needed them?
Front radius arm bushes Rubber OEM Only.
Your 2" lift should not need an adjustable Panard front or rear, if you need bushes though then certainly consider HD Panards
The above list is some big coin though mate.
![Cool](images/smilies/cool.png)
Check out my Toy -->
Rogue Dung Beetle
chrisc2306 (31st July 2014)
30th July 2014, 02:25 AM
Unless you want to throw some money around I would only upgrade your Tie Rod, and don't bother with poly style bushes, you will only be changing them again real soon. My 2 inch lifted GQ only had the mods below and I was very hard on my rig(not stupid just adventurous ha ha) and never had any problems, it behaved well on the road. I did camp road at cruiser park many times and jumped the old girl quite more than I'd like too on the old sneaky sand dune.
2 inch lift
*Rubber genuine style bushes
*Terrain tamer Steer Damper - rubber style bushes - converted to eye to eye instead of factory pin to pin for better response
*Road runner offroad Heavy duty chromoly tie rod and heavy duty tie rod ends(bent original into spaghetti many times), with gu steer box conversion. Broke 2 steer boxes before I made the switch, has been 2 years since a broken box now. Those chromoly tie rods have lifetime warranty against breaking or bending.
I now have four inch's of lift and have upgraded much more than that, but only because I had to to get the steering and diff geometry back in spec. If you are rough on the old girl you cant go past a good set of rear lower trailing arms, roadrunneroffroad does good quality ones for a good price. You will not really need upper adjustables at 2 inches. Your adjustment will be so small the benefit would be very minimal. I have never broken a single arm on mine but I have seen quite a few bent and broken rear lower trailing arms and as such i now have chromoly lowers.
Hope that helps ya make up your mind dude
31st July 2014, 06:03 PM
#8
Thanks for your advice guys its much appreciated its nice to know what is worth upgrading and what is not no point in throwing money away!
31st July 2014, 06:29 PM
#9
Another noob question sorry in advance, but on my warrant sheet it says that the front suspension lower arm bushes also need replaced are these called by another name because I can't seem to find them
31st July 2014, 06:40 PM
#10
chrisc2306
If your talking about the arms that go from the chassis to the diff, they are called radius arm bushes. Get them from patrol-a-part. Cheapest genuine bushes.
1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me
![Tongue](images/smilies/tongue.png)
The Following User Says Thank You to lhurley For This Useful Post:
