13th April 2014, 11:40 AM
#11
Is it just one side not working?
13th April 2014 11:40 AM
13th April 2014, 11:46 AM
#12
Hardcore
Yeah mate just passenger side brake works fine just no red when headlights are on
![](image.php?s=0f9d974a662947fce047aaebadd140b1&u=9781&type=sigpic&dateline=1356176199)
IF ITS NOT BROKEN IT MUST BE A PATROL
13th April 2014, 11:51 AM
#13
If you still have OE globes you'll find over the years the lead on the base of globe will wear away.
sometimes if you hit the lens it will come good, but a sign all globes may need changing if the same age.
Something a lot of ppl forget to do
13th April 2014, 01:08 PM
#14
Hardcore
All sorted the solder on the connection was preventing the power to flow through
The Following 2 Users Say Thank You to healy For This Useful Post:
BigRAWesty (13th April 2014), threedogs (13th April 2014)
22nd July 2014, 07:07 PM
#15
I have a very similar problem to this, but my indicator and rear light isn't working. Brake light is fine. Where abouts did you find the solder connection? My globe holders look fairly well sealed up.. the wire disappears into the plastic and I can't see anything from there.
23rd July 2014, 06:59 AM
#16
i had thne issue of none working taillights once and as i searched it was the wiring from under the seat to the lights
