Page 389 of 1056 FirstFirst ... 289339379387388389390391399439489889 ... LastLast
Results 3,881 to 3,890 of 10551
  1. #3881
    How's the serenity boots's Avatar
    Sep 2011
    Paule mine came off with the gerni pressure washer and I used some eucalyptus oil to remove the sticky gunk from the duco, once removed I used soapy water to clean and presto done. No razerblades were hurt or used in this process.
  2. The Following 2 Users Say Thank You to boots For This Useful Post:
    Bloodyaussie (29th June 2014), Paule (30th June 2014)
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Apparently fine fishing line works well as well, then your weapon of choice for removing any remaining glue residue
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  5. #3883
    Jul 2012
    N/a
    Got her covered in mud
  6. #3884
  7. The Following User Says Thank You to sil3nt_dr3ams For This Useful Post:
    Clunk (2nd July 2014)
  8. #3885
    Oct 2013
    Port Hedland
    Started on the second battery install
  9. #3886
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    sold one and bought one today. 2005 st-s td42i
    Such is the rule of honour.
  10. The Following User Says Thank You to macca86 For This Useful Post:
    lhurley (2nd July 2014)
  11. #3887
    Expert sil3nt_dr3ams's Avatar
    Mar 2013
    Can of Wax and grease remover and razor blade. I took my side common rail stickers off a while ago and this done the trick.
    Sent from my SM-G900I using Forum Runner
    Mate I tried every thing to remove my decals of my last nissan. this went for weeks here and there, every chemical known to man. I stumbled on a really good steam iron, with a tea towel soaked in petrol covering the base. Using a piece of acrylic with a sharpened edge on it . My patrol had decals from the front to the back
    full door job. took weeks to get thru the first quater panel. Once i worked it out took couple hours to do the entire car without breaking a sweat.
  12. #3888
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Those bloody decals. Mine used to have pin stripes alone the sides but there wasn't actually anything there to remove. The actual paint had taken the form of the pinstripe and no amount of rubbing with any chemical would remove it. Only thing that fixed it was sand paper and a respray.
    IMO and should be taken with a grain of salt.
  13. #3889
    175 Post(s)
    Quote Originally Posted by sil3nt_dr3ams View Post
    This is the stuff I used. I had to take off the common rail sticker on both sides, of the car as for some reason they looked farked. I had one of them razor blade tools, and just began taking the sticker off in portions. Inch by inch. This wax and grease remover dries quickly , but it's effective if you soak the decal in it. So I'd spray a crapload, on one area, wait 10 seconds or so, and then it just comes off with the blade, then move onto the next bit, or repeat in same area or respray area if it dries. Yes I did dig into the paint, in a few tiny spots, but nothing major. It was an hour job for both stickers.
    http://www.supercheapauto.com.au/onl...d=288523#Cross
  14. #3890
    Western suburbs of Melbourne
    11 Post(s)
    Changed the headlight globes on my Missus's VE Calais and my GU as we both had a globe out.
    Her car piece of piss.
    The GU was a nightmare, no room for hands.
    Driver side was easier with a little more room but the passenger side was a b-itch.
    I got scratches all over my wrist and hand.
    No room between the back of the light and the air box.
    I just removed the headlight assembly out by removing the fastening bolts, even that was annoyingly difficult.
    By now you guys are probably pissing yourselves laughing but hey, that's the way I roll.
    Everything the hard way.
    Lesson learnt, take to someone else to fit globes. Lol
