23rd June 2014, 09:13 PM
Hub noise after changing from 4x4...
Been noticing a noise.
So, here are some symptoms:
When I switch into 4 wheel drive and go I don't notice much. But when I switch back into two wheel a grinding sound will start up - very fast sound, like a baseball card in a bike's spokes. Reversing and backing up will make this noise go away.
I read the forums about this and it sounds like the hub. The outside of the car says 'auto-locking hub'. Sounds like this is a common problem. Even my description of the noise is common - I found another thread where I guy described it the same way: "suddenly a noise exactly like a kid holding a stick on the spokes of his bike." (http://www.nissanpatrol.com.au/forum...o+locking+hubs)
When the noise first started it would only make a noise after switching back into two wheel drive. But now I have noticed a bit of a noise - though not the same one, when going slow in 4 wheel drive. I don't know if it is there when going fast though for there are too many other noises. I did go and buy a bunch of small screws and washers and, after drilling little holes, I systematically fastened every My patrol is more like a dirty old farm truck so I suspect the grease has long since departed.
I assume it started out not fully disengaging and has now progressed to not fully engaging.
I notice nothing when in 2 wheel drive (after reversing, of course).
I have looked at the manual and read this forum. I am researching what I need to do. Perhaps it just needs a cleaning and a lubrication (for this car is very old and was not maintained at all until I bought it).
Is this an easy job - to at least take it off and give the hub an inspection?
P.
23rd June 2014 09:13 PM
23rd June 2014, 09:35 PM
Moderator
Hi mate, yes the hub is simple to remove and relatively self explanatory to then strip down. Give it a clean up and you should be ale to figure out its function and that will let you see which piece is making the noise.
Pack with grease a d refit assuming it is serviceable.
![Cool](images/smilies/cool.png)
Check out my Toy -->
Rogue Dung Beetle
24th June 2014, 01:53 AM
I was reading about people manually locking the hub with a wheel brace. Maybe I am missing something; but there does not seem to be anything to attach any tool to on the outside of the hub (the hub on my machine looks like this:
![](http://www.nissanpatrol.com.au/forums/images/imported/2014/06/29.jpg)
When I get a chance to pull them off I'll snap a few pictures - these may have been other for 20 years...
MT
24th June 2014, 09:12 AM
Moderator
What country are you in? Auto hubs in Australia don't look like your pic. They have a hex bolt head in the centre the same size as a wheel nut and they are always set to auto but you can manually set them to Lock.
Rogue Dung Beetle
24th June 2014, 09:50 AM
Had the same thing happen to me recently. Changed from 2 to 4wd on the fly as I hit a gravel road. Changed back to 2wd when I hit the black top again and after about five minutes heard a humming from the front end. Turned out the hubs were still engaged...stopped...reversed...heard the two clicks...problem solved.
Just hoping you don't damage the hubs if they remain engaged.
24th June 2014, 09:51 AM
Moderator
This is the auto hub we have on the GQ and GU in aus
Rogue Dung Beetle
24th June 2014, 11:22 AM
My machine is in Kazakhstan. From stickers on the inside of the frame it looks like it may have spent some time in Germany. Other than that I have no idea of its pedigree.
Maybe in a few days I can pull it off and take a look.
Lots of people write about the grease and how it is important not to put too much on. How do I know when I have the correct amount?
MT
24th June 2014, 11:40 AM
#8
Moderator
modustollens
MT
Makes sure everything has grease on it but don't pack the hub with grease or it has no room to function.
Rogue Dung Beetle
24th June 2014, 11:45 AM
#9
Once I take out the bolts will it slide off easily or will it need to be pried off? Are the pieces locked in place or is there a danger of all the pieces spilling out onto the ground?
As for cleaning - is there a preferred method?
MT
24th June 2014, 11:47 AM
#10
Moderator
Should come off in a single piece. Just give it a tap with a mallet and it should come off.
Degreaser spray and function is the go
Rogue Dung Beetle
