Results 1 to 9 of 9
Thread: Antenna question
    Mar 2014
    Sydney
    Antenna question
    Hi guys, can anyone tell me what is the best antenna to use I have a pic of my current one I will be crossing the Simpson Desert in July and just need to be sure. Thanks image.jpg
    .......... TPC's Avatar
    63 Post(s)
    Quote Originally Posted by Chefpatrol View Post
    The antenna you have is a Polar ground plain independent and should be a good antenna.
    You can remove the short whip on top and change it for a 3dB gain antenna when you want to transmit over a long distance on reasonably flat ground.
    Did it come with a longer whip?
    Mar 2014
    Sydney
    No it didn't. Thank you for your help.
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    That looks like a 3dBi whip on it to me. Get a higher gain whip and you'll have the best of both worlds depending on terrain. Short 3db for hills and 5-9db for flat
    Lucus30's 1999 GU ST TB45E
  5. #5
    63 Post(s)
    That looks like a 3db whip on it to me. Get a higher gain whip and you'll have the best of both worlds depending on terrain. Short 3db for hills and 5-9db for flat
    That is a unity gain antenna on there.
    There is a lot of confusion when referring to antenna gain as some will quote dBi figures which make the antenna sound like it has more gain.
  6. The Following User Says Thank You to TPC For This Useful Post:
    Chefpatrol (22nd May 2014)
    Wont need the rod holders they might/will frown on them interstate
  8. The Following User Says Thank You to threedogs For This Useful Post:
    Not if they have a rod in them .
  10. #8
    they still threaten to fine me last year even with rods in them..think the cop was having a bad day...I asked where would I put my rods and she said that aint her problem but they aren't allowed out fornt,I even said if they went straight up I would hit every power line..13-15 foot rods.....still didn't care....
    Mind you it was one cops out of about a dozen we had seen over a distance of about 10,000km.like I said having a bad day
  11. #9
    Sep 2013
    16 Post(s)
    Yeah mate I should have said 3dBi. Antennas should always be listed with the gain in dBi otherwise it doesn't make any sense
    Excuse my laziness
  12. The Following 2 Users Say Thank You to lucus30 For This Useful Post:
    Chefpatrol (22nd May 2014), TPC (22nd May 2014)
