19th May 2014, 06:25 PM
Smart like tractor
Yield in gold Can with a white lid . It's not the cheapest but It is farkin good Stuff
96 GQ coil/Cab
08 G6eT
![](image.php?s=d1d38b05930eabde04d86845e3946968&u=1281&type=sigpic&dateline=1483248064)
Bloodyaussie (19th May 2014)
19th May 2014 06:25 PM
19th May 2014, 06:49 PM
threedogs
Is it possible to use an impact socket tool,
you can put screwdriver ends in them
It's a rifle..... no way of using a socket.
Send me pics Pete ..
19th May 2014, 07:40 PM
Its just the FN mauser(60yrs old) being a stubborn git of a thing, original military barrel has probably had a squillion rounds through it over the years and flings lead wild at anything over about 25m.
I found a diy recipe for a penetrating oil thats supposed to work better than most of the brand name offerings, uses a 50/50 mix of ATF and acetone, might give that a go as I've got both of those in the shed.
I must have some kind of thing with barrels, my Enfields barrel was loose when I got it
21st May 2014, 09:44 PM
Okay, I can officially vouch for the abilities of a 50/50 acetone /auto trans fluid mix as a penetrating oil.
Throw out your wd40, crc, rp7 and just fill a spray bottle with some of this.
The Following User Says Thank You to Irish For This Useful Post:
21st May 2014, 10:04 PM
irish
okay, i can officially vouch for the abilities of a 50/50 acetone /auto trans fluid mix as a penetrating oil.
had win did we
21st May 2014, 10:45 PM
Big win mate, one love tap on the action wrench and she came good. Very satisfying. Made the action wrench from scratch from some flat bar and some rhs box section, cut the barrel blocks, with that home brew oil it was easy as. just shows what you can do with some basic tools.
21st May 2014, 10:49 PM
#17
22nd May 2014, 01:53 PM
#18
Irish
cant open the pics mate
22nd May 2014, 01:59 PM
#19
Irish
FAIL !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You new to this internet thingy mate ...bwa ha ha ha ha ha!!!
22nd May 2014, 02:18 PM
#20
Bloodyaussie
wasn't thinking of a socket,,, just the flat screwdiver attachment, Received a PM so all is good now
