13th June 2012, 08:56 AM
Body Lift & Cab Cut Requirements for Queensland
As of mid April 2012 body lifts do not have to have Queensland Transport Approval given first. They can now be Approved by an Approved Person, under the K3 Code.
Must comply to below:-
50mm maximum lift
Body blocks must be same diameter as original
High Tensile bolts must be used
Blocks can be steel, alloy or high density plastic or poly
All gear lever boots must be retained and floor sealed
Brake lines & clutch lines to be routed correctly
Good workmanship to apply
Airbag sensors to remain operative as per manufacture design
Body cuts can now be complied by an Approved Person without seeking prior approval from Queensland Transport. A K3 plus other codes will/could be required such as LK1 and if needed a LO1.
If I can be of any assistance regards vehicle modifications please give me a call on 0418 745 830 or drop me an email.
Regards
David Metcalfe
Approved Person 2868
Reason: change
The Following 4 Users Say Thank You to Xtreme 4x4 Sport For This Useful Post:
growler2058 (13th June 2012), NissanGQ4.2 (13th June 2012), patch697 (17th September 2012), Sherro (24th April 2014)
13th June 2012 08:56 AM
13th June 2012, 09:45 AM
Hi David,
Does this mean you are able to inspect and approve or advise changes required to get a vehicle to comply with state laws?
I bet you've seen some real interesting vehicles (both good and bad)LOL
13th June 2012, 10:40 AM
Hi, yes I can.
And if not sure Vehicle Standards are only a phone call away.
Yes I have seen & heard of some very interesting modifications
David
The Following User Says Thank You to Xtreme 4x4 Sport For This Useful Post:
17th September 2012, 08:44 PM
Do you think it will ever be possible to have a lift higher that 2 inches certified?
18th September 2012, 09:08 PM
Rocklobster
No, is the best answer.
You will find that the rules do not state 2" but 1/3rd of rebound bump stop height. So height will vary depending on vehicle.
So it is just as easy to say 2"
David
27th April 2014, 09:45 AM
Hi David, Why is it i see older 4x4's around cairns with lift's higher than 2" and police pass them with no interst.
Is it worth the risk & what are the penltes
27th April 2014, 10:15 AM
Sputnik
No idea why that is.
But the risk is yours if you go higher then what is allowed.
And if anything does happen with an illegal lift you may wipe your insurance.
