26th April 2014, 01:09 PM
nissan patrol y61 4" lift kit
hello all patrol expert..need some advise on 4" lift..im currently installed adjustable pandhard rod,shock and spring 100mm,extended swaybar link,
the question is..is drop box needed for better comfortable ride?and how bout the 5deg castor plate?is it necessary ? or ill just install the dropbox..ive been doing some reading,that the 5deg caster plate is only for 5" above..thanks for any advise
26th April 2014 01:09 PM
26th April 2014, 01:15 PM
and by the way..my patrol seems unbalance..its like more heavier on the right side..i dont know how to explain it..lol..im not very good on english..when i check the height..left side is off about 1inch and right side is less 1inch..that aint normal is it?or my coil spring must switch viseversa to fix this..
26th April 2014, 02:43 PM
BIG & BALD
1" difference is little off, perhaps driver side springs were fitted to passenger side.
I believe driver side are slightly taller.
The Following User Says Thank You to MEGOMONSTER For This Useful Post:
seekers282 (26th April 2014)
26th April 2014, 03:17 PM
MEGOMONSTER
okay..that might be the solution..im gonna check my oem standard spring..which one is taller..thanks mate
26th April 2014, 03:54 PM
Hardcore
seekers282
Hi,
If you have left hand drive vehicles over there then I would expect the drivers side to be a little higher than the passenger side when empty. This is done to accommodate extra weight of the driver.
Jack
26th April 2014, 04:17 PM
BIG & BALD
Apollofish
Hi, If you have left hand drive vehicles over there then I would expect the drivers side to be a little higher than the passenger side when empty. This is done to accommodate extra weight of the driver.
And sub tank.
26th April 2014, 08:16 PM
and about my 1st question..anyone can answer it? about the drop box issue..if i install the drop box..do i still need to install the 2-3 deg caster correction bush?or just use the standard bush?1
26th April 2014, 08:20 PM
seekers282
No need to use both together....
Use Drop Boxes over Caster Correction Bushes, as you can then keep the Standard Nissan rubber Bushes - much better
Mic
The Following 2 Users Say Thank You to happygu For This Useful Post:
Rickie3 (27th April 2014), seekers282 (26th April 2014)
26th April 2014, 08:21 PM
Apollofish
Hi,
well mine is right hand driver vehicle..
26th April 2014, 08:23 PM
happygu
Mic
ok thanks happygu ..im gonna have to swap the 2deg bush thats currently installed back to standard bush..
