26th March 2014, 09:40 PM
Headlight Warning Buzzer
I often drive with my lights on during poor weather or early mornings to work. To save a flat battery I recently fitted a headlight warning buzzer and thought I'd share how I did it. If I turn off the car ignition with the lights on even parking lights the buzzer will sound.
USED:
Basic 12 volt buzzer with 2 wires, red for positive and black for negative or earth.
Insulation tape.
Soldering iron and solder
Philips screwdriver
Pliers or crimping tool
Wire strippers
1. I remove the steering column plastic cover by removing the 5 screws from the bottom of the column.
2. From the right side of the column I found the brown plug with 2 red wires and 2 blue wires. The blue wire with black stripe which is the top wire of that brown plug. This wire is the parking light wire. (i tested it with a meter) This is where I connect the RED wire from the buzzer. I stripped this blue wire with black stripe and soldered the red buzzer wire to it. I made sure I insulated the connection with electrical tape.
3. On the other side of the column (left) of the steering column I found the white plug which is the ignition wiring. Unplug the plug and noted the black wire with white stripe. Its the middle wire on second row of the plug. This is where I connect the BLACK wire from the buzzer. Again I insulated the connection.
Refitted the plastic around the column and all good.
The headlights and parkers work as normal when the car is running or the key is on accessories. If I turn off the key the buzzer will sound until I switch off the lights. The buzzer was too loud so I wrapped some insulation tape around it.
Cheers 4by.
The Following 10 Users Say Thank You to 4by For This Useful Post:
04OFF (27th March 2014), Bloodyaussie (27th March 2014), CPOCSM (27th March 2014), dannypatrol (13th November 2014), my third 256 (27th March 2014), NP99 (27th March 2014), Rickie3 (27th March 2014), tallman (30th November 2014), Yabb (26th March 2014), Yendor (27th March 2014)
26th March 2014 09:40 PM
27th March 2014, 12:15 AM
Hardcore
Awesome, been meaning to do this for ages, your instructions/pics should make it very easy now ![Bigthumbup](images/smilies/bigthumbup.gif)
Where did you get the buzzer (jaycar?) Pic or part number would be very helpful too
27th March 2014, 06:51 AM
I thought it was STD on GU's
27th March 2014, 07:10 AM
Brilliant mate... I often leave my lights on and people are forever pointing out this fact.... then I reply like a smart ass "Nah its fine I have 3 batteries" but really I am thinking shit I left the bloody lights on again!!!!!
I will be doing this mod in the next few days for sure...cheers!!!
27th March 2014, 07:40 AM
04OFF
Jaycar will sell buzzer. Search BUZZER on their site...
Heres 2 from their site you could use.
"AB3452 RRP $3.95*
This handy little solid state buzzer operates between 5- 15VDC.
Used in many applications"
"AB3462 RRP $3.95*
It offers medium to loud sound output, low current consumption and is extremely durable."
Cheers 4by
Can I put a Holden badge on my Chevy ?
The Following User Says Thank You to 4by For This Useful Post:
27th March 2014, 07:53 AM
threedogs
Maybee late models have them Im not too sure but Im on my 4th GU and neither had the buzzer.
Cheers 4by
27th March 2014, 08:03 AM
Hardcore
threedogs
Nah , the early ones didn't have it, weird i know, my 1998 nissan pulsar had it, but my 1999 GU has not ![Frown](images/smilies/frown.png)
4by
"AB3452 RRP $3.95*
"AB3462 RRP $3.95*
$3.95 !, so expensive (lol)
Thanks again mate, this will help a lot of people out for sure
27th March 2014, 10:13 AM
27th March 2014, 02:55 PM
4by
Strange both my 98 and 2000 model ST's have it on them
27th March 2014, 03:26 PM
Hardcore
One explanation is if the factory buzzers likes to die ?
Can someone with one in a early GU track down where the noise comes from, and take a pic of it (thats if its not inside the body control module)
