Results 1 to 9 of 9
Thread: 3rd anf 4th gear
    Expert statok's Avatar
    Oct 2013
    Taree NSW
    3rd anf 4th gear
    Hey.
    Was driving the patrol the other day and i noticed that 3rd and 4th gear grinds abit and takes a extra push to get them into gear.
    Syncros?
    Oil?
    Im hoping its not a rebuild.
    The oil in it is about 12,000ks old?
    My mate suggested putting a thicker oil in.
    Any info would be great
    North brissy
    Oil type can make a difference. What oil did you put in last time? You must use a API GL4 oil in the patrol manual.
    Oct 2013
    Taree NSW
    Im trying to remember mate.
    Whats the best oil to use? I will head out tomorrow and grab it. I do remember it needs 6.1ltrs
    North brissy
    I use a 75w-90 semi synthetic gear oil by hi-tech oils. As long as it's API GL4 then you should be fine either in a 75-90 or 80-90.
    Oct 2013
    Taree NSW
    Where can i get the hi tech oil from in western sydney
  6. #6
    Oct 2013
    Taree NSW
    I can only find API GL5 oils
  7. #7
    North brissy
    10th one down is the GL4
    http://www.hi-tecoils.com.au/?page_id=764
    And here are the details for the Sydney area.
    http://www.hi-tecoils.com.au/?page_id=272
    I went from castrol EPX80-90 which is a GL5 oil and noticed cooler box temps and smoother changes. The smoother changes didn't happen immediately but it's certainly nicer now after 10k than what it was.
  8. #8
    Mar 2014
    Had a similar problem after buying second hand, took it back to dealer and they replaced synchro. No charge. All good now.
    Trev
  9. #9
    Oct 2013
    Taree NSW
    I got the oil. Direct from hi tec oils
