Results 1 to 8 of 8
Thread: Would this be the right spot to install my catch can?
    Beginner HiluxMichael's Avatar
    Dec 2013
    Austria
    Hey guys,
    just wanted to know if this ( see pic ) would be the right spot to mount my provent 200.
    Please keep in mind that my Patrol is a LHD model, so plenty of space between engine and battery...
    Mick
    What motor is that mic? The catch can goes "inline" in the hose that goes from the top of the motor and back to the air intake. Where to actually mount the can is up to you. I made a bracket for mine and its mounted where the ABS module would normally be for ABS model Patrols. So its mounted near the lhs bonnet hinge on my car.
    Dec 2013
    Austria
    Hi mudski!
    Sorry, it's a 2.8td.
    As mine is a LHD (i am from Austria), i've got more space on the other side of the engine, as brake booster, ABS block and all this things are mounted at the "exhaust side".
    Just wanted to know if it's ok to connect the catch can directly to this hose on top of the engine and mount it somewhere close by (fuel filter).
    Mick
    Mar 2014
    sorry to hijack the thread, but are the catch cans most use and setup vent to the atmo with baffles and drain back into the sump?
    cheers
    Quote Originally Posted by GU_Mudstar View Post
    cheers
    No. That is illegal here in Oz I believe. It needs to be routed back into the air intake.
    As for the OP. You could put it on the other side of the engine I suppose if that is the only place you can. Well, if you have no choice then...The only issue I can see is the longer hoses may be an issue, but shouldn't really...
    Dec 2013
    Austria
    But wouldn't the postion (red arrow on pic in first post) be the best to connect the can?
    The hose on the 2.8 goes to the right, then behind the block to the exhaust-side, doesn't it...?
    Regards
    Mick
  8. #7
    There should be a hose running from the top of the motor and back into the air intake somewhere. Hard to tell on your pic. The catch can goes inline of this hose.
  9. #8
    Dec 2013
    Austria
    Many thanks mudski, i guess we're talking about the same
    Will post pics once done...
