Results 21 to 30 of 32
Thread: **trailer brake lights not working**
    Expert Warwick89's Avatar
    Oct 2013
    Cairns
    If you take the cover off the plug and plug it in you can test the voltage while under load.
    It's a solid metal plug so I can't just take the cover off I'd have to take the whole casing off and then I don't think I'd be able to get the plug to mate
    2010 GU7, ZD30 CRD. ARB: bulbar, scrubbars, rock sliders, roofrack, front and rear air lockers, twin compressor. OME 2" lift, mickey T's ATZ P3 33" tyres x 6, opposite lock rear twin spare rear bar, Wurton 46" light bar roof mounted, draw system, clearview mirrors, redarc gauges: boost, EGt, engine pressure and temp, trans temp, battery. Dual battery system, 12,000lb warn winch, DYI sound/heat proofing.
  2. #22
    .......... TPC's Avatar
    63 Post(s)
    Have you tried tracing the wiring on your car back to where it is connected?
  3. #23
    Oct 2013
    Cairns
    Started looks like I may have to take the draws out
  4. #24
    82 Post(s)
    Place your bets:
    A) Loose screw behind plug?
    B) Bad connection at wiring loom?
    C) Crimped or squashed wire
    D) Corroded connection caused by water ingress
    E) One of the above plus a below average earth on the trailer or socket.
    F) Wiring that has been twisted together then taped over.
  5. #25
    63 Post(s)
    Quote Originally Posted by Warwick89 View Post
    I had a look at mine and the wiring is taken from the back of the lights on the bumper, do you have a GQ or GU?
  6. #26
    176 Post(s)
    Mate I went through the same dilemma 5 days ago. Whoever wired up my trailer plug originally used those wire tap connectors or whatever they call them. Water got in, they got so badly corroded there was no metal left in the connectors. Absolutely atrocious job, those things are farkin' s***. They should be banned!
    I ended up going to Nissan and buying a proper Y harness, plugs straight into the lights on each side and a earth crimp to chasis, no crimping or wire cutting needed.
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Mine used to be one of those, if you take the screw out the back it will side back along the wiring. I also had similar symptoms to you, i ended up just redoing the whole thing with a new plug. no issues now.
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  8. #28
    X2 with gaddy I've had nothing but trouble with lights working and not working on my trailer
    my son soldered all connections for me. still the same ,,,,,,,,,,,,,,there was one more wire with a FRICKEN scotch lok on it.
    re moved and soldered that joint , now all is good . point is never trust a scotch lok, solder every joint with shrink sleeve over it
    You can buy trailer plug LED test lights from SuperCheap auto
    do you have electric brake controller fitted ??
  9. #29
    Patrol Freak gaddy's Avatar
    redlands
    So what was the out come ?
  10. #30
    all joins were soldered so basically one wire from globe to the battery works like it should now properly
    plus I have electric brakes, everything works fine now.
