Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: 2" or 3" what's better to fit if running 33's
    Expert ThomasWatson's Avatar
    Jan 2014
    Sydney NSW
    Hey all just trying to decide what lift I want I can get a 3" king spring with amada shocks for $895 that includes brake lines and castor correction bushes
    Just don't know what to get
    Feb 2011
    Shed
    45 Post(s)
    2" will fit 35's
    Thomastown, Melbourne
    6 Post(s)
    2inch with 33's no problem at all... once you go to 3 inch then you need to start looking at spending more on lots of other crap!!!!
    Legendary happygu's Avatar
    2 inch is a far simpler lift as you only need springs and shocks.
    3 inch gets you into caster correction, sway bar extention links, possibly panhard bars, longer diff breathers, possible extended brake lines
    Mic
  6. The Following User Says Thank You to happygu For This Useful Post:
    Bloodyaussie (14th February 2014)
    Jan 2014
    Sydney NSW
    I ordered 3" with everything
    Jan 2014
    Sydney NSW
    As it was cheaper and in the long run I want to run 35s just want the clearance
  9. #7
    330 Post(s)
    Reconsider the caster correction bushes as they are junk and your way better leaving the Nissan rubber bushes in place. Buy bolt in 3" drop boxes for the win mate.
  10. #8
    Jan 2014
    Sydney NSW
    Is it worth getting this order cancelled as it doesn't come with much looking over the fine print and getting a 2" kit from suspension stuff
  11. #9
    330 Post(s)
    I assume the Amadas in the kit are Not the remote res units?
    The 3" kit will need
    Shocks
    Springs
    Brake lines
    Sway bar extensions
    Some kind of caster correction.
    Diff breather extensions.
  12. #10
    Jan 2014
    Sydney NSW
    Okay so I can send a message to them and say don't cancel it can you supply sway bar extensions
