Results 1 to 10 of 11
Thread: My TB45e now has more power.
    Feb 2011
    Pretoria, South Africa
    Good day
    My Patrol received a chip and stainless steel freeflow exhaust, the head was gasflowed and they did some modification to the airfilter and the cam timing and then it was dynatuned. The BEFORE run was 82.5kw and 234Nm on the wheels and AFTER was 99.8kw and 261Nm. In November last year I did a dynarun at another company and the results were 92kw and 270Nm. Although the results from the 2 companies differ there is definitely an improvement in power. The acceleration from 0-100km/h is faster. At 120 with the overdrive off I don't have to step so hard on the pedal to maintain the speed on an uphill.
    Regards
    Johan
    A 17.5% increase in power is a good result.
    There will always be differeces between dynos so it's a good idea to get the before and after readings done on the same dyno (as you appear to have done) and if possible at similar ambient temperatures and humidity to get reliable readings.
    Tony
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Mate, well done on the improvement.
    The petrol motors go fairly good but can go hard with a few mods!
    ________________________
    ______ 2017 D-Max _______
    Jun 2011
    what brand of chip did you use and what sort of power increases are expected from it?
    Feb 2011
    It is a Dastek chip which is developed in South Africa.
    They claim the conversion would do the following :
    25% increase in power from std
    15-18% increase in torque from std
    Fuel consumption should be+- 6km/l on open road travelling 120-130km/h
    I get 4.2km/l in town and 5.5 on the open road.
    I bought a 2004 4.8 Patrol a few weeks ago and will be selling the 4.5 soon.
  6. #6
    Advanced blazza's Avatar
    Jun 2011
    Sunny coast
    wow what a difference, i have a tb45 myself but duel fuel gas/petrol, can those same mods be done with running gas to, do u know?
  7. #7
    Feb 2011
    We don't use gas in South Africa, only fuel. I don't know if this will work with gas.
  8. #8
    Sep 2013
    gud fday, this chip we are referring to - where can i buy online? is it something I wilput/ where/ in order to get this results, Thanks
  9. #9
    Oct 2013
    do you know if i can install the chip to my tb48e 4.8 2006
    thanks
  10. #10
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    http://www.dastek.co.za/about_the_unichip.htm
    This site should answer some of the questions.
    1999 GU 4500 dual fuel
    Il dado è tratto
