Hi I am building a project using a gq chassis.I think the original master cyl was 1 1/16" and I have a 1" master cyl I can use, will I notice any difference or should I look for a bigger one.Thanks Mike.
You could use the smaller master cylinder but you will notice longer pedal travel. Ultimately you should use the correct master cylinder, don't mess around with brakes.
