A bloke named Archie Robertson. I can give more details if you require
6.5 Chevy, roof rack, uhf, Spotties, dual batteries, ARB Bullbar, 12, 000lb winch, (unfortunately not Warn) Safari snorkel, Dieselgas conversion, 2in lift, engine watchdog fitted, boost/EGT guages, front elokka fitted, rear power supply mods, turbo timer, dual wheel carrier rear bar.
That would be cool mate, how much did you get stung for(if you dont mind me asking)?
The other guy in Towong was trying to stitch you as a 2" lift doesn't require engineering.
Thinking $800 would be more ball park, Cuppa was $1500 I think for GMV upgrade, not sure if
pricing is set across the board or they charge what they like. They take in things like travel etc
That's what I was trying to tell him but we ended up in a slinging match over who was most qualified to answer the question, apparently as a mechanic I don't know s#$t.
Irish, his phone number is 03 9729 9776 or Mob 0408 373 536 and he is located at 15 Edelmaire st, he has a workshop there at the back of some other buildings and does inspect a lot of sweet looking mustangs . The cost was 880 for the inspection, but had to get additional heat guard around the brake pipes on the right hand side plus labour which cost a little more. They will check the car for full roadworthiness so try to solve any other issues prior to going and seeing them. I didn't have a GVM upgrade but wish I had.
Irish (29th December 2013)
threedogs (29th December 2013)
Thanks for the info Ian, much appreciated.
No worries Irish, good luck
