Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Fuel filter repacement 2.8td
    Aug 2010
    Hey guys,
    Just servicing the rig and am at a loss as to priming the fuel filter on the 2.8..
    Can anyone give me a quick rundown on what the go is?? And where the bleeding point is (havent played with deisels before)
    Cheers..
    Aug 2010
    thanks mate that makes alot of sense.. Just wasn't sure what i was looking at..
    I just got the car so Ive givin it a service so i know where it's at..
    Thing wasn't reaching operatin temp so pulled the thermostat out out anf found a stick about 150mm stuck in it ???? beats me how youd get it in there in the first place.. Thanks for the help.
    Banned
    Quote Originally Posted by Focaluck View Post
    Hmmmmm how odd??? first time for everything I guess.... Maybe a bit of bush mechanics gone on at some point?????
    Beginner sa_on_patrol's Avatar
    Aug 2010
    Mt Barker
    i'm just about to change my fuel filter on my 2.8GU aswell. what brand did you use and / or what brand do you recommend? I have used ryco oil filters before
    Patrol Guru Timbo's Avatar
    East Melbourne
    I'm pretty sure Ryco do fuel filters too. RYCO
    They aren't one of the biggest for no reason. Stick with them if you haven't had any gripes with their other products.
  6. #6
    Banned
    Quote Originally Posted by sa_on_patrol View Post
    I use Fleet Guard wherever I can as thay are the "No1" choice in the transport industry & ppl who own trucks don't tend to muck about when it comes to that sort of thing.
  7. #7
    Aug 2010
    Mt Barker
    Quote Originally Posted by patch697 View Post
    where do you get them and what price are they
    2.8TD GU, 0 - 100km/h in 2.8 minutes
  8. #8
    Banned
    Anywhere trucks are serviced or truck parts suppliers stock them as a rule & thay are generally more expensive than say ryco but not by much.
    The thing to be mindful of is the filters ppm (parts per million) ratio the higher the number normally means the better the filter but quality of materials also come into play so no matter what you by stick with a brand name product & buy the filter with the highest ppm available in its range
    I hope this helps
    Paul
  9. #9
    Aug 2010
    Mt Barker
    cheers paul,
    i found the part numbers for the 2.8 GU
    GU 2.8L Turbo
    Year 12/97-01
    FUEL OEM - 1640359E00, FG Number - FF5307
    LUBE OEM - 1520840L02, FG Number - LF3863
    Info from this pdf
    http://www.cumminsfiltration.com/pdf...s/3300964A.pdf
  10. #10
    Aug 2010
    Mt Barker
    what are the nippon max filters like??
    http://www.nipponmax.com/filters.html
