1st August 2010, 02:21 PM
Fuel filter repacement 2.8td
Hey guys,
Just servicing the rig and am at a loss as to priming the fuel filter on the 2.8..
Can anyone give me a quick rundown on what the go is?? And where the bleeding point is (havent played with deisels before)
Cheers..
1st August 2010 02:21 PM
1st August 2010, 06:01 PM
thanks mate that makes alot of sense.. Just wasn't sure what i was looking at..
I just got the car so Ive givin it a service so i know where it's at..
Thing wasn't reaching operatin temp so pulled the thermostat out out anf found a stick about 150mm stuck in it ???? beats me how youd get it in there in the first place.. Thanks for the help.
1st August 2010, 10:01 PM
Focaluck
Hmmmmm how odd??? first time for everything I guess.... Maybe a bit of bush mechanics gone on at some point?????
3rd August 2010, 12:41 PM
i'm just about to change my fuel filter on my 2.8GU aswell. what brand did you use and / or what brand do you recommend? I have used ryco oil filters before
3rd August 2010, 01:00 PM
I'm pretty sure Ryco do fuel filters too. RYCO
They aren't one of the biggest for no reason. Stick with them if you haven't had any gripes with their other products.
3rd August 2010, 01:24 PM
sa_on_patrol
I use Fleet Guard wherever I can as thay are the "No1" choice in the transport industry & ppl who own trucks don't tend to muck about when it comes to that sort of thing.
3rd August 2010, 01:54 PM
patch697
where do you get them and what price are they
2.8TD GU, 0 - 100km/h in 2.8 minutes
3rd August 2010, 04:26 PM
sa_on_patrol
Anywhere trucks are serviced or truck parts suppliers stock them as a rule & thay are generally more expensive than say ryco but not by much.
The thing to be mindful of is the filters ppm (parts per million) ratio the higher the number normally means the better the filter but quality of materials also come into play so no matter what you by stick with a brand name product & buy the filter with the highest ppm available in its range
I hope this helps
Paul
3rd August 2010, 04:58 PM
cheers paul,
i found the part numbers for the 2.8 GU
GU 2.8L Turbo
Year 12/97-01
FUEL OEM - 1640359E00, FG Number - FF5307
LUBE OEM - 1520840L02, FG Number - LF3863
Info from this pdf
http://www.cumminsfiltration.com/pdf...s/3300964A.pdf
3rd August 2010, 05:50 PM
what are the nippon max filters like??
http://www.nipponmax.com/filters.html
