Results 21 to 30 of 41
Thread: BBQ plate wanted!
  1. #21
    I used to use discarded cast iron BBQ plates in an angle iron frame.
    Then welded a 1" plumbing socket in each corner with screw in legs about 400mm long.
    All pulled apart and housed in a hessian bag or similar. M2cw
    Sep 2013
    Keen to see how this turns out.
  4. #23
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    No pressure Westy...
  5. The Following User Says Thank You to FNQGU For This Useful Post:
    BigRAWesty (9th December 2013)
  6. #24
    brisbane
    I can put up a pic of how the legs on mine work if you like
  7. #25
    Quote Originally Posted by megatexture View Post
    That's ok mate. Have enough people think I steal designs as is. (not here, the other site..)
    Ok thought I betta close a thread..
    Here are the finished products.
    So in the end I like the flat side over the Rod side..
    Enjoy.
  9. The Following 3 Users Say Thank You to BigRAWesty For This Useful Post:
    FNQGU (8th February 2014), megatexture (7th February 2014), P4trol (7th February 2014)
  10. #27
    brisbane
    Both look great mate, IMO I like the flat also I think it would be more solid to put a loaded camp oven on if wanted. Though slimline would pack nicely lol
  11. The Following User Says Thank You to megatexture For This Useful Post:
    BigRAWesty (7th February 2014)
  12. #28
    That's a good point..
    The Rod is quite strong. But yes the flat is stronger..
    brisbane
    Flat also catches snags b4 they fall lol
  14. The Following User Says Thank You to megatexture For This Useful Post:
    BigRAWesty (8th February 2014)
  15. #30
    if that's no to your fancy just use a cast iron BBQ plate in an angle iron frame.
    weld sockets in each corner and cut 4 legs to either screw on or slide in
    will put pic soon
