1st December 2013, 07:20 AM
#31
Gq turbo
It has brand new toughdog panhards all bearings were done swivel and wheel bearings a week and a half ago
Sorry, missed that bit.
How are the rear bushes? As mentioned your car is being pushed so any movement from the rear will cause issues.
Another thing and it sounds crazy but have you tried different Tyre places?
Diffrent places, different techniques and some have reported of vast differences with mechanics in the same town..
It can be a pain mate. Hang in there, we'll get ya rolling straight..
If you can maybe worth going over all bolts yourself as New things take time to seat and sometimes will shrink or move.
Did you have issues before fitting adjustable panhard rods?.
Gq turbo (2nd December 2013)
1st December 2013 07:20 AM
1st December 2013, 09:11 AM
#32
i had a very similar issue i changed bearings bushes and the steering rods but still couldn't find it lots of wheel balancing from various shops still no good and it only happned randomly around 70-90ks mainly after the new tyres but was their a little before i had it to a few mechanics couldn't find a fault the tyre shop blamed the car in the end i give up untill recently when i swaped the front and rear wheels over and it's pretty much gone back to the way it used to be before i put the tyres on. they were yoki at-s
00, Dx 4.2 turbo, dual batt, 3in exh, Boost contrl, boost and egt guages, GTX2867r, cc intercooler, 3.5in airbox mod, roof console,4 x hid spots and hid projectors, snorkle ,winch,reverse lights and tinted windows, safari tuff clutch, now tuned to 155rwhp also 2000 ford fairmont ghia, 1987 mitsubishi 4wd ute converted to buggy
2nd December 2013, 02:51 PM
#33
Thanks it had no issues for years then it started wobbling so I started off buying adj front and rear panhards and drag link also rtc damper but it still did it so then had all swivel and wheel bearings replaced I have tried tightning all bolts to no avail someone told me the rtc toughdog damper is not for a 4inch lift and I needed the bigger version???? Also does the rtc exaggerate the wheel wobble??? Also my rig has spent time sitting on and of with flat tyres could this ruin the tyres?? The wobble doesn't always happen but when it does the car is uncontrollable it shakes so violently
Gq patrol lwb 4.2diesel running gt3076 top mount intercooled (with fan) 15psi 4inch springs 2inch body lift slowly adding bits as I go love it
![Smile](images/smilies/smile.png)
2nd December 2013, 05:21 PM
#34
that sounds like a serious safety issue to me
2nd December 2013, 06:00 PM
#35
Flat spots wouldn't be helping for sure.
Are you running 40psi??
Have you changed drag Rod ends??
With the bigger offset if could be exaggerating a small amount of slop.
What speeds are the wobbles starting?
Lift shouldn't a dampener. It still travels the same.
An RTC dampener do help with the wobbles, as I mentioned they mask issues.
Most like adjustable dampeners over rtc's as the rtc make steering heavy..
Tbh, I'd start looking at the rear to.
You have done panhard rods, (how many k's ago??) so move onto the upper and lower arms.
Use genuine rubber.
If you haven't got modded arms yet now may be the time to grab adjustable uppers, or longer lower arms.
2nd December 2013, 08:20 PM
#36
I had the 80-100km/h wobbles and tried all the usual things. In the end I went to a truck alignment place (Queanbeyan truck align) and they fitted an "offset knuckle bearing castor correction kit" (or something like that) fixed it. 10,000 km on and it is still good.
2nd December 2013, 08:29 PM
#37
Cheers yea it has a brand new adjustable drag link all parts have travelled less than 60ks the wobbles are between 60/80kmh
2nd December 2013, 08:32 PM
#38
"offset knuckle bearing castor correction kit" (or something like that) fixed it. 10,000 km on and it is still good.[/QUOTE]
What is this? I have castor correction plates
2nd December 2013, 09:10 PM
#39
Smart like tractor
Gq turbo
What is this? I have castor correction plates[/QUOTE]
The swivel hub bearing is offset shifting the hub only. I dont think they are needed, castor can be corrected.
Did the tyre shop tell you what castor you are actually running?
96 GQ coil/Cab
08 G6eT
![](image.php?s=2efb7a0c4ce715ee0ae26e05a88d90fe&u=1281&type=sigpic&dateline=1483248064)
2nd December 2013, 09:26 PM
#40
I had a similar issue once, for me it ended up being the lock nut for the front adjustable panhard. Tightened her right up and all good.
