Hey guys,
Just servicing the rig and am at a loss as to priming the fuel filter on the 2.8..
Can anyone give me a quick rundown on what the go is?? And where the bleeding point is (havent played with deisels before)
Cheers..
Hey guys,
Cheers..
thanks mate that makes alot of sense.. Just wasn't sure what i was looking at..
I just got the car so Ive givin it a service so i know where it's at..
Thing wasn't reaching operatin temp so pulled the thermostat out out anf found a stick about 150mm stuck in it ???? beats me how youd get it in there in the first place.. Thanks for the help.
i'm just about to change my fuel filter on my 2.8GU aswell. what brand did you use and / or what brand do you recommend? I have used ryco oil filters before
I'm pretty sure Ryco do fuel filters too. RYCO
They aren't one of the biggest for no reason. Stick with them if you haven't had any gripes with their other products.
Anywhere trucks are serviced or truck parts suppliers stock them as a rule & thay are generally more expensive than say ryco but not by much.
The thing to be mindful of is the filters ppm (parts per million) ratio the higher the number normally means the better the filter but quality of materials also come into play so no matter what you by stick with a brand name product & buy the filter with the highest ppm available in its range
I hope this helps
Paul
cheers paul,
i found the part numbers for the 2.8 GU
GU 2.8L Turbo
Year 12/97-01
FUEL OEM - 1640359E00, FG Number - FF5307
LUBE OEM - 1520840L02, FG Number - LF3863
Info from this pdf
http://www.cumminsfiltration.com/pdf...s/3300964A.pdf
2.8TD GU, 0 - 100km/h in 2.8 minutes
what are the nippon max filters like??
http://www.nipponmax.com/filters.html
