watching this with interest as I have a 9L and 4L airtank at home to install and not to sure of the piping it came with, bought some 225psi rated hose to use instead
www.swat4x4.com
Rated to 240 degrees and 300psi that's why they are stainless braided?
SD, might have to tap into your knowledge when I get ready to mine or find someone in Perth so I can have a gander at 1 installed
Sent from my iPad using Motorculture mobile app
www.swat4x4.com
Looks can be deceiving the one in my pic is stainless 90deg and 145 psi, whats a length of that one worth line.
Gonna be a sweet set up though will be interesting to know how fast it's going to do 18- 40 psi in comparison to others. Should be a walk in the park
Lol we talk bout that shit later mate, I'm about two hours away from being finished. Im just bolting the compressor in atm. remove front expose the conduct with my other compressor power feeds and add new one back to battery. Drop in another relay next to the other compressors relay double the switching wires and run another power feed to battery.
oncedisturbed (28th October 2013)
These thumper are unreal I've been using the first one flat out for nearly two years and I run my nail guns at work with it.
Cylinder: 60mm
Voltage: DC 12V
Air Flow: 160L/min
Maximum pressure: 150PSI
Maximum amperage: 45A
Can be hard wired
Auto reset thermal protection
Heavy-duty 2m power cord with battery clamps
Features built in circuit breaker and automatic thermal cut-off
8m nylon hose with inline pressure gauge
Maximum voltage: 13.8V
Maximum amp draw: 45A
Maximum restart pressure: 150PSI
Maximum operating temperature: 140°F
Minimum operating temperature: -67°F
Will have a switch to run either one or two compressors.
According to the maths should be 11.3cfm
cgm (28th October 2013), oncedisturbed (28th October 2013)
Eerything is wired in and running perfect, so how are we going to test this setup?
Definetly a neat set up
www.swat4x4.com
