Found the jaycar stuff. At 4kg per m^2 and the price is very cheap so might be worth putting a couple of layers down. Very intrigued.
http://m.jaycar.com.au/m_productView.asp?ID=AX3680
NissanGQ4.2 (27th October 2013)
Good price, around $100 for the floor.
But only 2.3mm thick.. I'll see if our local jaycar has Stock?
well just dropped into the local JayCar. Can get it, unfortunately no display piece.
But he tells me its self adhesive, very pliable and heavy.. So good start.
Might just get one square and see what its like..
Parksy (25th October 2013)
Hey I got this off the jobsite today it might be worth further investigation.
http://www.spec-net.com.au/press/0310/ecow_100310.htm
Weird, they are using a different method.. Light weight density..
How are we going to trial it cheaply??
Westy I have about 4 square meters here. Mate the stuff is lightweight squashes together 4-5 mm and its has the foam and dyanamat . least if you put it under floor cover you can pull it out dry it.
Would be good in the doors and use the self adhesive stuff on the floor
Well this is what i figure, I think it would be better on the floor least you pull it out inspect yours floors and its not a permanent fixture. I'm thinking bout removing all the foam under my vinyl floor lining and running this under it. I've already completely coated the floor with body shilzs/sound deadner so the floor is sealed. So something like this would be ultimate pull out high pressure wash and let dry.
Will it work when compressed but?? You see all that style of dampener at 100, not squashed??
Dunno, look forward to hearing some results. Lol
BigRAWesty (26th October 2013)
