Results 1 to 10 of 13
Thread: my diy drawers. cost ... under $100
    Expert ozzyboy's Avatar
    Oct 2011
    springwood, qld
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    TB42E manual 1996 GQ 30 year anniversary
    33" maxxi bighorns, 3" EFS & Accessories
  2. The Following 6 Users Say Thank You to ozzyboy For This Useful Post:
    AB (1st July 2013), Jimmyboyjr4 (29th August 2013), my third 256 (24th October 2013), NissanGQ4.2 (1st July 2013), oncedisturbed (20th October 2013), Warwick89 (20th October 2013)
    583 Post(s)
    Neat finish ozzy!!
  5. The Following User Says Thank You to AB For This Useful Post:
    ozzyboy (3rd July 2013)
  6. #3
    Very nice very well thought out set of drawers you got there mate
  7. The Following User Says Thank You to Clunk For This Useful Post:
  8. #4
    Jun 2011
    How'd you keep the cost down so low? Left over stuff from other projects?
  9. #5
    Patrol Freak krbrooking's Avatar
    Beveridge, Melbourne
    They look really good man, makes me want to rebuild mine and do something similar.
    Live life, Love life.
    Snatch straps on towballs can harm and/or kill!!!!!!
  10. The Following User Says Thank You to krbrooking For This Useful Post:
    ozzyboy (23rd September 2013)
  11. #6
    Oct 2011
    springwood, qld
    Quote Originally Posted by soundfx View Post
    2 sheets of ply and a couple off cuts courtesy of work . cost = $0
    Carpet was a end of roll at bunnings. ( can't remember exactly, but buggar all )
    Screws, glue etc I think 30 bucks tops
    I stayed away from runners or bearrings for 2 reasons. The laminate on the marine ply slides easy on the base laminate. Not easy enough that they slide by themselves but easy enough. Other reason was the cost. a good set of runners would have doubled the build cost.
    I went the height I did to fit whatever I like in the drawers, fit the 80l waeco on top, fit a duel battery in the rhs compartment, all recovery gear in lhs compartment, and the sub in the face
    cheers
    ozz
  12. The Following 2 Users Say Thank You to ozzyboy For This Useful Post:
    AJTich (20th October 2013), oncedisturbed (20th October 2013)
  13. #7
    Expert AJTich's Avatar
    Oct 2013
    Andrews Farm
    Lightbulb
    Man, that is great. I've seen a pic of what I want for mine, and your pics, and setups make me think I could do it too.
    Can only hope it looks as good as yours.
    A&J
  14. The Following User Says Thank You to AJTich For This Useful Post:
    ozzyboy (24th October 2013)
  15. #8
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    Good job on the setup and finish
    www.swat4x4.com
  16. #9
    Expert Warwick89's Avatar
    Oct 2013
    Cairns
    Nice finish mate, better then a bought one.
  17. The Following User Says Thank You to Warwick89 For This Useful Post:
  18. #10
    Oct 2010
    Old Bar, NSW
    Great build, If you had to buy the ply would you go with the same? Supporting batteries and serious speakers would be better in a heavier construction.
    It looks like 19mm which is fairly heavy, as you say the surface is good for the drawers to slide and that is only on that 19mm form ply.... I think.
    A lighter ply if used could be fitted with that "Teflon" strip as Drifta Kitchens use. Corners can be reinforced with 40x40x1.4 mm aluminium angle ($26.00 per 3mtr from Bunning's) I am always looking at keeping the weight down.
    Like the design and use of space, a good DIY for a good price.
    Macca
  19. The Following User Says Thank You to macca For This Useful Post:
