Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Auto windows modification.
    Western suburbs of Melbourne
    11 Post(s)
    Does any body know if you can make the passenger side window into auto down/up like the driver side on the GU's.
    Can I just buy an auto button in the spot of the passenger window button or is it the motor that does the auto bit.
    It's been something that has been bothering me for a while but I have a feeling it can't be done. Not cheaply anyway.
    43 Post(s)
    I think it's a little more detailed than just the switch. You need some sorta end switch, I think the work like an over load switch on the drivers side..
    But I'm not sure where that circuit is.
    In the q they have a black box inside the door which holds a lot of electronics. Im pretty sure Its the controller for the other Windows but possible has the limit switch to..
    Nit sure what would happen if you bolted one into the passenger side setup with the 2 stage switch..
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    MEGOMONSTER (11th September 2013)
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    The GUs have a limit switch in the driver door regulator and circuitry in the drivers master window switch that controls the auto function for the drivers electric window.
    I think it would be very difficult to set up the auto function on the passengers window.
  6. The Following User Says Thank You to Yendor For This Useful Post:
  7. #4
    11 Post(s)
    Of course it would, why would Nissan make it easy.
  8. #5
    Did they make a left hand drive version of the GU/GR ?????
    BigRAWesty (11th September 2013)
  10. #6
    11 Post(s)
    Already sounds expensive.
  11. #7
    43 Post(s)
    They would have, but electrical would just be swapped..
    11 Post(s)
    So I need to find a cheap complete drivers door and change the internals.
  13. #9
    43 Post(s)
    I'm not sure how the system would run with 2 controllers?? You could try.. Have and Extinguisher at the ready but..
    @ Kallen if LHD wouldn't it be handed as in mirror of RHD.
    Or do you think they just swap the lot and only change armrest buttons
    Nah,,, has to be left handed to fit...cause its a left handed door.
    My thinking is if you take RH unit out it won't fit on LH side it needs to be Mirror image to work.
    Sort of like the RH mirror won't fit on LH side
