10th September 2013, 06:54 PM
#21
CERTIFIABLY INSANE
threedogs
@ Drew as well as what Roofy said up in the tropics etc flies, mozzies etc attack at all hours so throwing
the swag in side the Fly wire inner frame of a GEO tent would make sense
I get all that but why not just roll out a sleeping mat and bag and use the tent rather than the swag inside the tent?
Tip tip tip......tap tap tap....
10th September 2013 06:54 PM
10th September 2013, 07:38 PM
#22
Drewboyaus
I suppose a swag is "your bed". Its already got a matress and blanky, its water proof when rolling around in the back of your patrol and you can just grab it out of the shed and go knowing that everytting is included ready to go
Hello from Under Down Under!
15th September 2013, 08:40 PM
#23
Yep, exactly. Your swag is your bed and it is safely kept out of the dust etc. by being rolled up and ready to go. Storing all your bedding separately is in my books more of a pain in the ass than having the swag rolled up nicely and ready to be laid out. It has to go somewhere anyway, and the ability to throw them on the roof is pretty bloody handy. Where else does everyone put the mattresses, sheet, sleeping bag etc.? One of those age old compromises I suppose...
6th December 2017, 10:24 AM
#24
I recently purchased a Darche Ridgedome, made in China. I would give it a 1/5 rating.
* They are too mean to put eyelets in the window flaps.
* The ridgepole supports the tent in one place which is off centre. It would be nice to see at least support in 3 places. As a result of lack of support, the tent looks very "saggy-baggy" and this "may" result in water pooling in severe rain.
* The swag was erected in the yard and hosed to "weather" it. There has been some rain (bordering on heavy) during that time and there has been some minor water leaks, but perhaps that is part of the "weathering" process, however it does not fill me with confidence.
Having expressed my disappointment in my Darche, it does appear to be the best of a bad bunch bearing in mind that I wanted a swag that was 200cm * 110cm, at least 80cm high and easy to erect.
The Following User Says Thank You to mr_jsd For This Useful Post:
mad66 (12th January 2018)
6th December 2017, 11:41 AM
#25
Swag material today is a polyester cotton blend and it does not respond all that well to the weathering process as used to exist when canvas was 100% cotton. Generally the seams are configured with a sealing tape and thats about as good as it gets. If it still leaks I would check the zips and also apply a waterproofing agent either in a spray can or brush on to all the seams for good measure.- you won't win with the supplier. I have a Darche Swag, very happy with it. Mine did not leak from memory, and has been thru everything from dry dusty hot to freezing cold under 6" snow and torrential rain. I have a Darche stretcher, bought to match the swag and don't think much of it to be honest - not as sturdy as perhaps the price would indicate it should be.
6th December 2017, 06:49 PM
#26
I have the Kings swags are they are shit. They cannot be pulled tight from end to end to stop sagging and therefor pooling when it rains. Lucky I dont use them often enough to warrant spending good coin on one. My old Darche swag I had was great. Survived many downpours with zero leakage.
6th December 2017, 07:02 PM
#27
The 747
mudski
As much as I hate to say it, my kings swag is great quality. If you use the ropes it pulls tight. Mines a couple of years old now though, don't know if they've changed since then.
6th December 2017, 07:19 PM
#28
Administrator
Winnie
Yep same but I haven't had mine out in elements away from the awning.
Having saying that though when seasoning it three times with a drenching from the hose only minimal drops got in.
6th December 2017, 07:20 PM
#29
Administrator
mudski
I do have sagging in mine too mate.
6th December 2017, 07:43 PM
#30
AB
Yeah to over come this I use a second rope and attach it lower down on each end of the rod and peg it out in the middle. If ya get what I mean.
