9th September 2013, 10:44 PM
04OFF
Piston slap Troy ?, was your donor car a "manual" gearboxed car by any chance, and how many Ks on the engine ?
How is cold starting, any noise after it starts ?
Donor car did have 214 on it but it come up trumps with sump off inspection.
9th September 2013 10:44 PM
9th September 2013, 11:52 PM
Maybe hydraulic lifters might be buggered as they make a rattle if knackered
10th September 2013, 03:43 PM
To me the noise sounds like its pining buts thats normal when you give the motor a quick stab coz of the rush of air going into the motor. If you have had the ecu MAFless tuned the tuner will have to adjust the settings for the MAP sensor and TPS to react faster.
11th September 2013, 06:51 AM
I pulled the starter out and have found some marks on the heat shields where the exhaust has rubbed them, so I'll modify them to rule them out. I'm sceptical in regards to it having something to do with the tune as it started about 30klms after the tune. But you never know! I have checked the torque converter bolts and they are tight. Process of elimination I think!!
Cheer for your input guys
11th September 2013, 08:44 PM
Problem solved!!! It was the IAC Valve. It was dirty and sticking when the engine got hot. Cleaned it and the noise has gone.
Thanks for all your input guys, I appreciate it
Troy
The Following User Says Thank You to Thirsty For This Useful Post:
04OFF (11th September 2013)
