28th June 2013, 08:07 PM
Smart like tractor
nissannewby
Galvanised once done??
I think so
96 GQ coil/Cab
08 G6eT
![](image.php?s=1448a10bbf3ce83d44481c7fab9f9abb&u=1281&type=sigpic&dateline=1483248064)
macca86 (8th August 2013)
28th June 2013 08:07 PM
14th July 2013, 06:22 PM
Smart like tractor
I picked up the sides of the tray the other day. I have to go back to work for another week. But when I get back get the rest of the steel and start building!
Here is a mock up of the headstock, main rails and side rails, the main rails used to be the side rails they were already bent up when I got some advice on tray design, so intread of turfing them I just moved them to the middle
96 GQ coil/Cab
08 G6eT
growler2058 (14th July 2013)
8th August 2013, 03:04 PM
Smart like tractor
Well I made a start on the Tray today. getting the tray off by Myself Was a bit of a Mission, but I managed it with a couple of tie down straps.
I have tacked the head stock together and It is just resting on the mounts Atm
I think the wheel arch is a bit too high but I will know for Sure when I flex it up and see where the wheel Sits on full compression.
96 GQ coil/Cab
08 G6eT
NissanGQ4.2 (8th August 2013)
8th August 2013, 04:47 PM
looking good , are you going the hidden wiring route for any work/reverse lights fitted
8th August 2013, 05:36 PM
Hardcore
Nice work we will make a show flex truck out of her yet
Such is the rule of honour.
8th August 2013, 06:20 PM
Moderator
Hey Bene, did you Friend Mick on FB? If you did have a look through his pics mate! He has done an awesome tray for is cutdown. Based on the one Biders makes. Looks sweet! Good spot for ideas ![Wink](images/smilies/wink.png)
Or jump on the Biders website for pics of their trays too.
Are you going to do scrub rails? If so then make sure your tray width is the same width as the scrub rails ![Wink](images/smilies/wink.png)
Is this going to be ready for the October Meetup?
Check out my Toy -->
Rogue Dung Beetle
8th August 2013, 07:20 PM
#17
Hardcore
Ben-e-boy
I think so
Dont forget your drain holes and to brace it or fully build it then gal it
8th August 2013, 08:39 PM
#18
Smart like tractor
MudRunnerTD
I hope it's ready for October, not So Much the tray or the bull bar but the Motor Most importantly
96 GQ coil/Cab
08 G6eT
8th August 2013, 08:50 PM
#19
Moderator
Ben-e-boy
Ummmmm? Yeah you will definitely need a Motor mate
Rogue Dung Beetle
8th August 2013, 09:13 PM
#20
Smart like tractor
96 GQ coil/Cab
08 G6eT
